HOW TO Convert 12v to 13v
Status
Not open for further replies.
Usamaj
Jul 14, 2022
13
i am working on ups for the router i have some questions
1. i am using lithium battery 3s whose output when full charged is 12.6 so i need 13v to charge it i have adopter 12.22v i need to boost the voltage is there any way which transfer is best that work without producing too much heat i don't want to use xl6009 or any module ... just simple circuit.
2. 12v*1.5a= 18watt == 9v*2a = 18watt. what if i give 9v 2amp to a 12v load is it work?
crutschow
May 7, 2021
987
To increase a voltage you need a boost (or buck-boost) switching regulator.
As Harold noted, an off-the-shelf module will be the simplest and cheapest way to do that.
Otherwise buy an adapter with a higher voltage.
Usamaj
Jul 14, 2022
13
Thanks for your response is it possible to modify the adopter?
Martaine2005
May 12, 2015
5,299
Not without opening it.
Is it like a laptop power supply or a phone charger/PSU? Or a heavy little walwart?
Martin
Usamaj
Jul 14, 2022
13
it is a router adopter
Martaine2005
May 12, 2015
5,299
That’s a SMPS. I doubt you can alter it . Get another adapter with a higher voltage. Or a linear transformer. Or of course a boost converter.
Martin
ivak245
Jun 11, 2021
144
Have you actually measured the output of the plug pack? They may say 12VDC, but the no-load voltage could be as high as 16vdc. Then you just need to go through a variable 3 terminal voltage regulator, as long as the under load voltage is above 13 volts.
Martaine2005
May 12, 2015
5,299
The power supply shown is most definitely a SMPS.
Martin
CircutScoper
Mar 29, 2022
300
Pry it open and take some photos of both sides of the circuit board. It's just possible the brainacs here (not me!) will be able to suggest a workable modification -- provided you're good at soldering.
Delta Prime
Jul 29, 2020
2,989
The solution should be cost-effective and compact, suitable for integration into our system. We need to achieve this within [specify timeframe] to proceed with testing and implementation.
We are borge!
The solution is assimilation!
Resistance is futile. :)
Status
