How to determine what voltage 20-watt halogen bulb I should use in a modified projector?
H
HiC
I want to replace the lamp in a projector with a halogen bulb of a given
wattage. I realize the mounting is going to have to be customized, but as
far as the voltage, would I simply need to find one that's rated at the same
voltage as the original projector bulb?
All input appreciated.
Eeyore
That's certainly how I'd do it.
Graham
John B
Graham
On the other hand, you could purchase two bulbs at half the rated
voltage and connect them in series. That might work too.
H
Homer J Simpson
same
Why? What do you expect to gain?
Charles Schuler
Save money, would be my guess ... check the price of projector lamps! Ouch!
martin griffith
Nope
The colour temperature variation would be significant
martin
H
HiC
Ouch!
While projector lamps can be pricey, that's not why. I need a lower wattage
light source for creating an "aerial" image using a condenser lens to
capture film. A regular projector bulb is way too bright, would completely
overwhelm the camera optics.
Charles Schuler
HiC said:
Ouch!
wattage
Then you can select the watt rating that you need at the same voltage.
H
Homer J Simpson
wattage
Is this a slide projector or a video projector? One way would be to 'bounce'
the image off one or two pieces of glass which will bring the brightness
down considerably.
John B
find >> > one that's rated at the same voltage as the original
projector bulb? >>
martin
Sorry forgot the smiley.
