bene-tam
- Jan 1, 1970
- 0
my device fails the EN61000-4-4 test about burst/EFT
it is powered up with 110/230VAC to 12VDC adaptor.
the supplier cannot filter the transients inside their circuit, it has
asked us to do it ourself(i wonder if the input to my device is still
a small AC imposed on a large DC offset)??
how should i do the filtration with resistor/MOV/inductor/zener diode?
the 12VDC in is connected to a 12V to +-5V converter to drive the main
circuits.
the design by the ex-colleague consists of a 1n4001 for polarity
protect, a relay for "true" connection once the polarity is correct, a
fuse for limiting max current.
i surfed the web and found out that the input should be filtered
seems bead inductor would do the job, isnt it??
pls advice, thx so much
circuits.
