How to generate about 25kv high high voltage with Back EMF from single coil?
russwr
Dec 20, 2019
39
How to set up, put together, generate about 25kv high voltage using 1.5 -3 Millihenry inductor coil with 10amps current flow? Back Emf E volts = L Henries times change in current amps di divided by change in time dt second. Is that a 10Mhz solid state oscillator pulse needed with fast transistor? An ignition coil only shows 130 volts reverse volts with 4MH that runs the secondary side and that is in milliseconds , instead of microseconds. The value of .6 microsecond (10Mhtz) shows in formula for 25kv. The standard autotransformer output is not AC, and pulsing DC cannot use a multiplier circuit to raise up voltage. (Maybe it would be just easier to wrap wires around inductor to make a step up transformer as primary and secondary.) Doesn't the Tesla coil set up have an unusual step up ratio at resonance of Pr + Sec, without using standard turns ratio?
