How to hook up a 2 wire thermostat
computer-joe
Oct 6, 2016
29
I have an old thermostat which i want to replace, but i don't understand exactly how it's supposed to be done.
It's a simple baseboard heater with no fan, air conditioning or anything fancy
It only has 2 wires, and the instructions are no good
it was supposed to be simple but turned difficult in minutes
Where exactly are these wires supposed to go
old thermo wiring
Thermo
Instructions
i also have a second thermostat which i did not succeed to install it,
instructions
why oh why is this so hard
does anyone know exactly how i am supposed to hook these up??
Externet
Aug 24, 2009
944
The original thermostat is meant to interrupt maaany Amperes at the current the baseboard heater element consumes in series to it. Works/rated usually on 230VAC
The replacement thermostats shown are wimpy ones meant to signal 24V relays inside an airconditioner/furnace/fan unit to turn on/off.
Wrong device for your needs. If you hook it up, will leak its smoke. For sure.
Externet
Aug 24, 2009
944
Check the plastic nut connectors have healthy, clean, tight splices inside, at both ends of the heater assembly before replacing thermostat. Diagnose, probe for continuity at the existing thermostat and voltage supply presence. It usually is :
ACphase1circuit breaker-----x----thermostat-----x------heater element-----x-----circuitbreaker2ACphase2
x= splice/joint/connector
Listen for a 'click' when turning knob.
----> https://duckduckgo.com/?q=baseboard+thermostat&t=canonical&iax=images&ia=images
----> http://www.homerepairforum.com/forum/attachment.php?attachmentid=1987&d=1348147051
Be careful touching live wires, will give you the giggles. Work safely.
