How to improve upon this comparator driven LED circuit?
Angy15
Nov 18, 2015
27
If Vcc is less than 23V transistor is ON LEd2 & buzzer operates and if VCC is greater than 23V it is OFF buzzer does not operate and LEd1 is ON. But somewhere between around 23.100V both LED 1 and Led2 are ON and there is some sound in buzzer. This effect is happening when there is transistion from VCC>23V to VCC<23V somewhere around 23.1V. How can I improve upon on this circuit so that there is immediate switching between Voltage levels .
This circuit is a part of complete schematic in which when Voltage at Pin2 is greater than Pin 3 output Pin 1 is low and when voltage at pin 2 is less than pin 3 output Pin1 is high .
Alec_t
Jul 7, 2015
3,821
What is the buzzer voltage rating?
Do you want LED1 to be on when LED2 is off, and vice versa?
Amar Dhore
Dec 2, 2015
129
what are your input voltages? what is your common mode voltage?
AnalogKid
Jun 10, 2015
3,058
You don't give the opamp input conditions for the various Vcc conditions, so there is no clear answer.
Also, what is the purpose of R1?
Also, what is the need for Q? If the LM158 can sink enough current to light LED1, can't it source enough current to light LED2?
ak
Angy15
Nov 18, 2015
27
Buzzer voltage is 25V.
Yes I want LED1 to be ON when LED2 is OFF and vice versa
Angy15
Nov 18, 2015
27
ak
actually I am using LM339 thats why I am using R1
AnalogKid
Jun 10, 2015
3,058
In that case you will have only about 1 mA through LED2.
Again, there is nothing in your schematic that would cause the device output to change state because of a variation in Vcc. No input circuit, no good answer.
ak
Colin Mitchell
Aug 31, 2014
1,416
What you need to do is add a Schmitt Trigger. Either turn the op-amp into a Schmitt Trigger or replace it with a Schmitt Trigger.
you need a resistor acrod the greed led and its resistor to prevent the LED from turning on a little when the output is supposed to be high.
The original circuit was correct in this respect.
Amar Dhore
Dec 2, 2015
129
1. Why is your VCC is changing?
2. What are your inputs?
3. What is purpose of R1?
