Install Wire Guard in the RK3588 Forlinx Desktop image
Solution: Mount the Forlinx Desktop image file into the development environment for installation.
(1) Download qemu-user-static in the development environment
sudo apt-get install qemu-user-static
(2) Mount the img image of Forlinx Desktop to a directory, I have mounted it to the test directory.
sudo mount focal-rootfs.img test/
(3) Use the chroot command to enter the test directory
sudo chroot test/
(4) Install WireGuard
apt-get install wireguard-dkms wireguard-tools wireguard
Solutions that cannot be used after installation:
To add the TUN and WireGuard options to the kernel, proceed as follows:
1. Modify the build. Sh in the SDK to add the $KMAKE menu config;
2. Execute. /build.sh, search for TUN and wireguard in the graphical configuration interface and check them off;
Save and Exit.
3. Overwrite OK3588-Linux _ defconfig with.config
cp kernel/.config kernel/arch/arm64/configs/OK3588-Linux_defconfig;
4. Re-flash the image;
5. Set the IP.
sudo chroot test/
Save and Exit.
5. Set the IP.
