How to Program Renesas Audio Processor without Datasheet available
luckwill7
May 15, 2023
18
My Working Project picture....If you don't Mine can you send Arduino Atmega 2560 Board to Audio Processor Connection schematic sir....I used 2k2 Resistor series in Atmega 2560 Board and 3k3 input grounding resistors....but when the code was uploaded to board...sound was working fine...but secondly when I changing the inputs or volume decreasing it was not changed...it was fixed and not changing...how to solve this problem
luckwill7
May 15, 2023
18
hello sir...i am waiting for your reply.. and i want your for completeing this project.
geo98
Aug 7, 2023
6
If you got sound on the outputs of the audio processor, then the connection between the arduino and the processor is fine. Is the volume not adjusted on any output from the processor or on a specific one? Put the code from the arduino here, maybe there is a mistake in the code.
luckwill7
May 15, 2023
18
Ok....I will try to fix that..do you have any other Testing code or Full code with Lcd+Remote Ir Code.......Sir Can You send Your Arduino board to Audio Processor Schematic connection sir
luckwill7
May 15, 2023
18
Hello sir... I fix my problem ...the problem was solved..i am getting output sound...the code also working fine...Thanking you sir for helping me.. but i am getting output only on SL Channel...how to fix this problem sir
wfdudley2
Dec 18, 2024
R2A15218FP is identical to R2A15220FP, both in the internal structure and in the command. The input selector is a little different. The complete datasheet is not published online anywhere, but there is a summary datasheet in which there are data and information related to the command part.
I have attached the datasheet of the R2A15220FP chip, and a library with which you can command both this and the R2A15218FP compatible with arduino. Be very careful when switching the internal switches of these chips, a mute circuit is necessary on the integrated outputs, otherwise you risk "blowing" the speakers. I know it's been a while since the topic was started, but maybe it's useful.
This is wonderful. I'm trying to repair an Onkyo HT_RC430 AV receiver and I think I can replace the processor (that won't run because the DSP is bad) with an Arduino or similar (ESP32 maybe) and get this to function as an audio-only receiver (I could care less about HDMI and fake concert hall simulations). Also, thanks for the hint about muting -- that explains the muting transistors on the outputs of the R2A15218FP.
