How to provide different voltages to the user, through a single channel (switching)?.
F
Franco
Hi folks:
I have a question.
From an I/O card I want to provide a variable output voltage to
energize
some little solenoids. In the board I have regulated 5, 12, and 24
volts, and
those are the voltages I want to deliver. I think I can deliver more
or less
300mA per channel (lets say: 5V-300mA, 12V-300mA, 24V-300mA). The last
are conservative values.
The important thing is: the output should be directed to the user
by using a single medium. So the user will have available 5, 12, XOR
24,
but not all at the same time. Nonetheless, those voltages are still
being used within the board, for some other tasks.
So, I am wondering, which technology to use for achieving that???
High side drivers and mosfets? (to switch between channels). (I dont
like
the space requirements)
Another smarter solution?
Drawing:
5 -------
12 ------- --------- output
24 -------
Best Regards...
Franco.
Hi folks:
I have a question.
energize
volts, and
or less
24,
like
Drawing:
5 -------
24 -------
Best Regards...
Franco.
try lm317 or send me email with more details on my private
[email protected]
with subject lm317 not good for my application then I will connect you
with the other solutions
F
Franco
[email protected]
Hi, unfortunately I have to use the voltages I have available and not
to generate them again.
The chip is also too big for my design. Space is an important
constraint in this case.
Cheers...
Franco.
John Fields
Rich Grise
Three reed relays with a little bit of logic for the "one and only one"
function.
Good Luck!
Rich
F
Franco
If you have to supply power to ground-referred loads, then I'd go
with P channel enhanced mode MOSFETS or PNP transistors.
How are you planning on doing the switching?
Hi, the switching control will be done by a microcontroller on board.
I am looking for P channel enhanced mode mosfet. Do I need
a high side gate driver for driving them?
Cheers...
Franco.
joseph2k
Cheers...
Franco.
Does it have to be able to change on the fly? (or do you have the luxury of
using a miniature rotary or slide switch or jumper or move a terminal to a
different position?)
F
Franco
function.
Good Luck!
Rich
Hi man, thanks for the tip. I think reed relays suit my needs. Thanks
again.
Franco.
F
Franco
Hi Joseph, it must be able to change on the fly, but speed is not
important.
I have a microcontroller with some pins available to make the
switching.
Cheers...
Franco.
joseph2k
important.
switching.
Cheers...
Franco.
In that case i recommend two "TO-5" relays (actually in a TO-99 8 pin can,
like an old op-amp). Two of them should have a smaller footprint than
three reed relays. You probably will need transistors to drive the relays
either way.
Y
YD
Hi folks:
I have a question.
energize
volts, and
or less
24,
like
Drawing:
5 -------
24 -------
Best Regards...
Franco.
How do you distribute to the appropriate solenoid(s) on the receiving
side, or how will you know which solenoid is connected?
- YD.
F
Franco
Late at night, by candle light, Franco <[email protected]> penned
this immortal opus:
- YD.
In our system, the user is responsible for that connection.
Greetings...
Franco.
