Is it likely a different digital converter box will provide more TV channels?
mm
If this is the wrong newgroup, I apologize and hope you can recommend
a better one.
channels?
Or is it more likely my friend, who has a plain antenna in the attic,
needs an amplified antenna in the attic? She doesn't want an antenna
on the roof.
Any recomendations for a powerful converter box? Maybe with a good
Guide. She has a coupon good for 3 more days. :)
She's in north suburban Baltimore (Reistertown) and can't even get
channel 45, a Baltimore channel, (it says "No signal") that came in
perfectly for her and me too in analog, and perfect for me in digital.
OTOH, she does get channel 7 in Washington DC. The city is about 50
miles from her, not sure where the transmitter is, but it's farther
than channel 45's.
W
William Sommerwerck
Reisterstown is more properly to the west of Baltimore. (I know because I
used to live off Liberty Heights avenue).
Bad reception might be due to a converter with poor sensitivity, but a good
antenna should be the first step in obtaining good reception.
If her coupon is about to expire, she might ask for a demonstration at a
retailer. (Good luck...)
Rich Webb
a better one.
channels?
on the roof.
than channel 45's.
Go to http://www.antennaweb.org/aw/welcome.aspx and also to
http://www.tvfool.com/. TVFool is nice in that it can give you the
azimuth (direction) and a nominal expected signal strength for
neighboring stations.
The antenna is more important than the converter box.
mm
I'm from Indiana, where 95% of the streets and roads run due north and
south or due east and west. I get confused here.
Well, the coupon is expiring and she's trying to decide whether to buy
another box.
Plus she has a cramped hot dirty attic which she won't go up in. I
can't go there, not because I'm fat, which I am, but because my
ribcage is too big for the hole in the closet ceiling, right in the
middle of my chest. (I have a little fat at my ribcage, but only maybe
an extra quarter of an inch.) I don't know why the hole is so small.
I'm 5'8", medium build. I have no trouble getting though the hole
into my attic.
Right. And some of the good ones seem available only on the web.
There are two models which will tune the converter box to a station at
a particular time, so if your vcr is set the same way, you can still
do timer recorders with a vcr, wihtout setting the channel each and
every time.
One is DTVPal Plus, which one "rater" said has 5 timer slots, although
the ad I saw for it doesn't say how many.
The other is Zinwell ZAT-970A`, which has 8 timer slots, although one
"rater"** said it had the lowest quality remote he had ever seen, and
one button was starting to break after only a few days. Other rated
it highly and said nothing about the remote.
**This guy said he had two converters and the DTVPal gave terrible
reception and that was improved in the DTVPal Plus. So I was
wondering how common that was.
Not only doesn't she get 45, but she had to add 7 several times before
it stayed, even though she watched 7 each time she added it. It would
still disappear later from the list of stations the up and down
buttons stopped at.
Thanks and thanks, Rich.
W
William Sommerwerck
Considering that the unit will cost no more than $20 with the coupon, you
might as well get another one.
