F
Fred Bloggs
- Jan 1, 1970
- 0
John said:John said:Don't need all that:
View in a fixed-width font such as Courier.
. HV
. 12V>--+-|>|-+--------+-----+-|<|------. |-
. | | C | | | |>
. | | .--B npn | | | |
. | | | E | | | |
. | [4.7K] | +-[51]-----------|-----+ |
. | | | E | | | |
. | '----+--B pnp |0.1u | | |
. [1K] | C === | | |
. | | | |Cbst | | | 1/2W
. | | '-----+----------------|-----+--[10k]-.
. +-------||SSN1N45B | | | '--|| sgnd
. | |> | | [100] |-
. 2N7000 ||-------+ -/ | === +---> out
. <| | 12VZ ^ ----- |0.01u |
. | | | |C555 |--' -
. --- | | |ASTBL| ^
. sgnd | | |10KHz| |
. CMOS ON >----' +----' pgnd
. /|\ 10mA
. CMOS EN >------------ \V/
. sgnd
And here's a slightly simplified version. Add the PV isolator for DC
drive.
ftp://66.117.156.8/Gate_Driver.JPG
One could also use a dip dc/dc converter and the relay.
John
What makes that simpler?
Um, having 1/5 as many parts? Being easy to analyze?
And actually, as long as we know the MOSFETs
can take fairly hefty transient peak power dissipation , I would prefer
to redo the input interface and stick an integrating capacitor in there
somewhere to slow the turn on/off to 15V/us range, especially now with
several of these circuits driving a common power bus, preventing
unrestrained slew rates from inducing transient currents into high
impedance nodes.
The gate resistor controls slew rate.
Also, I would want to at least attempt a backup
interlock by connecting OUT to the gate of the 2N7000 through a resistor
divider, or something, keeping the switching off while a second power
source was on the power bus, but not turning itself offThen there's
fusing on the HV lead to consider as well as protection of the LV stuff
in the event of HV component failure, possibly UVLO and maybe thermal
shutdown and other things...
More parts!
The dc/dc converter + relay is ideal for a one-off by someone who
doesn't want to do a lot of design and pcb fab. You could build one in
20 minutes, no simulation or debugging needed.
You could even use latching relays if that would help.
John
The OP may have significant investment in the system he's driving and
should be made aware of real world problems and damage possible with
oversimplified quick-make circuits...
