How to read and write the EEPROM of a PIC 18F442?
Alexander
I want to read and write the EEPROM of my PIC.
Unfortunatly, this doesn't work the way it's intended.
I want to call these functions to be called from an ISR and/or during normal
code execution.
I've added some code to restore the previous GIE state for this.
Could someone help me???
ThanX,
Alexander
WriteEE
MOVLW DATA_EE_ADDR ;
MOVWF EEADR ; Data Memory Address to read
MOVLW DATA_EE_DATA ;
MOVWF EEDATA ; Data Memory Value to write
BCF EECON1, EEPGD ; Point to DATA memory
BCF EECON1, CFGS ; Access program FLASH or Data EEPROM memory
BCF GIETEST ; Save current GIE state
BTFSC INTCON,GIE
BSF INTTEST,GIET
BCF INTCON, GIE ; Disable INTs.
BSF EECON1, WREN ; Enable Write
MOVLW 0x55 ;
MOVWF EECON2 ; 55h must be written to EECON2
MOVLW AAh ; to start write sequence
MOVWF EECON2 ; Write AAh
BSF EECON1,WR ; Set WR bit begin write
BTFSC GIETEST ; Restore GIE state
BSF INTCON,GIE ;
ReadEE ; Adress already in W returns
data in EEDATA
BSF EECON1, RD ; EEPROM Read
N
NewsGroup
code execution.
BTFSC INTCON,GIE
BSF INTTEST,GIET
I assume that somewhere you have the line
#define GIETEST INTTEST,GIET
Other than that it looks fine. - I assume that there is no banking with the
18 series as your code has no BSF STATUS,RP0 type instructions.
Mike.
Alexander
Het volgende bericht werd op ons ingehakt door NewsGroup
Yes, I do have that line included or something like that
with the 18 series as your code has no BSF STATUS,RP0 type
instructions.
I assume the same especially since MPLAB gives me no warning (normally it
does) about this.
ThanX I will take a look at it later with a clear head and add some debug
settings in the code to check everything out.
Alexander
Found the (at least one) problem.
How stupid can one be ;)
I called the code and forgot the return :(
Het volgende bericht werd op ons ingehakt door Alexander
Alexander
The code was not completly correct :(
It seemed that only 50% of the writes worked.
So I added a check/wait to see if the previous write sequence was finished
(a W bit somewhere in the intcom register).
After that it worked fine but the following question(s) hit me (not very
hard though):
How long does it take for a write to complete???
Is this (external) oscillator dependend???
Does each write take about the same time???
ThanX,
Alexander
