how to show routing slot and v-cut line.
eva liang
Dec 31, 2015
6
can i know that how many way could show the routing slot and v-cut line at the gerber design? Is there some way to show the rounting slot and v-cut line directly and easly at the gerber file?
thanks in advance.
eva
Arouse1973
Adam
Dec 18, 2013
5,178
Add instructions as a mechanical layer in the PCB design. Then output this as Gerber data when you do the other layers. Alternatively some of the higher end Gerber software packages allow you to do this properly with graphical elements. I guess you don't have a high end Gerber software package.
Adam
eva liang
Dec 31, 2015
6
yes, this is the problem you say and now i have slove the problem how to show the v-cut line and routing slot. Everything is going well.
thanks so much your help.:)
regards,
eva
