Dear all,
I recently acquired a pair of CCFL (backlight tube) from a damaged Sharp 10.5 inch LCD Display Screen Model LQ15x14. One of the backlight tube with pink and white wire is seen from img 0647 as attached.
I wish to use an inverter for CCFL (img 0646) to light up the backlight tube.
The description on the inverter is input:12V DC, output:900V 50HZ, Lamp: 300mm
Max:5mA-8mA
It seems the 12V DC input wire is red and black, the output is white wire with black cap plastic socket.
I am wondering which side of the white wire should go to either the pink or white wire of the CCFL and whether is it ok to use this inverter to light the CCFL?
Any advice and suggestions are appreciated. Many thanks in advance.
Max:5mA-8mA
