How to Test Variable Autotransformers?
I have a few variable autotransformers of unknown quality. What checks
and/or tests should be performed to ensure that they are (safely)
suitable for use? Can you recommend any URLs that I can study?
James Sweet
Suitable for use with what? A visual inspection and connecting one to power
and measuring the output is about all I've ever done to check them, they're
pretty simple devices, not much to go wrong really.
Roby
I have seen autotransformers designed for 400 Hz on the surplus market.
They will draw excessive no-load current if powered up at 60 Hz ... unless
you derate the input voltage by 60/400 = 0.15, which makes them rather
useless.
Hopefully, yours have nameplates indicating ratings.
Roby
Bill Jeffrey
If you can visually inspect the windings, that's a good thing to do. I
have run across a couple in which one or two of the turns developed some
slack - who knows how? The slider tends to catch on the slack turn,
which will probably make some fine fireworks if it drags the loop or
breaks it.
Bill Jeffrey
N
NSM
Slap a load on them. Add a regular light bulb. Otherwise check ground and
insulation.
N
Michael A. Terrell
useless.
Roby
That's easy enough to test for. Put a 150 watt lamp in series with
the primary and power it up with no load. If the lamp lights brightly
the transformer is either bad or built for a higher line frequency.
