How to trigger triac from PIC
Barry
I want to use a PIC to control a triac in a dimmer circuit. The light in
the circuit works off 12v a.c. I've already built a circuit which can
power the PIC and an opto-coupled signal to provide the zero-crossover
detection but I'm not sure how to trigger the triac. The PIC is powered
by a standard bridge rectifier circuit from the 12v a.c. fed through a
7805 to give the 5v and the opto-couple gives a 5v square wave in sync
with the AC supply but I obviously can't connect an output pin from the
PIC directly back to the triac gate, so how would I do this.
Many thanks in advance for any advice.
Andrew Holme
in the circuit works off 12v a.c. I've already built a circuit which
can power the PIC and an opto-coupled signal to provide the
zero-crossover detection but I'm not sure how to trigger the triac.
The PIC is powered by a standard bridge rectifier circuit from the
12v a.c. fed through a 7805 to give the 5v and the opto-couple gives
a 5v square wave in sync with the AC supply but I obviously can't
connect an output pin from the PIC directly back to the triac gate,
Another opto-coupler?
You can get opto-isolated triacs in 6-pin DIL packages e.g.
http://www.web-ee.com/Electronic-Projects/data/moc3021.pdf
ChrisGibboGibson
Check out MOC3011/3021
Made for just that purpose.
Gibbo
mike
As I recall, there's just such an ap note on light dimmers at the
www.microchip.com
mike
Return address is VALID.
500MHz Tek DSOscilloscope TDS520
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
http://www.geocities.com/SiliconValley/Monitor/4710/
Robert Monsen
Search on the microchip site for PICREF4, which is a PIC based design
for a dimmer. They connect an output to the triac gate through a 470 ohm
resistor!
Regards,
Robert Monsen
"Your Highness, I have no need of this hypothesis."
- Pierre Laplace (1749-1827), to Napoleon,
on why his works on celestial mechanics make no mention of God.
CFoley1064
Subject: How to trigger triac from PIC
Date: 10/18/2004 3:07 PM Central Daylight Time
Message-id: <[email protected]>
Hi, Barry. If the commom of the 12 VAC is at the same potential as the PIC
common, all you need are two resistors to trigger a low gate current TRIAC
(view in fixed font or M$ Notepad):
12 VAC Phase 1
o-------------------------------------.
VCC |
.---o----. |
| | ( X )
| PIC | |
| | ___ |
| P0o---|___|-o--. |
| | 470 | | _|_
| | .-. | V_A
| GND | | | '------/ |
'---o----' 470| | |
o----------o--------------o-----------'
12 VAC Phase 2
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
This is good for ON/OFF control of a lamp load. You have to make sure to use a
low gate trigger current triac (also called a logic triac), like the TECCOR
L2008L6. This triac is in a TO-220 package, can switch 8 amps, and only
requires a gate current of 5 mA for all quadrants.
It gets a little stickier if you want to do phase control of the load, like a
lamp dimmer. You will need some way to determine the zero crossing of phase 1
in the diagram above, then you can use the PIC to time the wait for the pulse
to the triac. A quick cut would give you something like this:
2.2K
1N914 ___ To PIC Input Pin
o ->|--|___|-o---------o
12VAC |
1N4732 /-/
Vz = 4.7V ^
GND
This will give you the positive zero crossing and, with a little software, the
negatrive zero crossing. Just remember that the logic signal will go high a
few degrees past zero crossing on the positive side, and a bit before the zero
crossing on the negative side. Using this, you can time the triac trigger so
that you can control the load. You want to be careful from a practical
standpoint in watching for voltage drops on the load interfering with the PIC.
Try a "star" ground between the 12VAC and the PIC power GND.
If the 12VAC is at a different potential than the PIC common, try a triac
trigger optocoupler.
Good luck
Chris
