How to trigger a triac?
Texton
Jul 27, 2012
14
Hi all.
I need to trigger a triac using a microcontroller, the question is how long does my trigger pulse have to be to enable the triac?
I found a value named: "gate-controlled turn-on time = 2us" in a datasheet. But is this is value i am looking for?
Thanks in advance :)
Or use an optically isolated triac.
rajnish
Mar 6, 2013
3
Triacs can be triggered by either a positive or a negative current applied to its gate electrode , Once triggered, the device continues to conduct until the current drops below a certain threshold.
TedA
Sep 26, 2011
156
Triggering triacs can be very complicated. Both the gate current and the load current through the main terminals are important factors, along with time and temperature. Polarities matter.
2us seems like a pretty short time. Triacs tend to be slow.
To get more specific advice you will need to tell us more about what you are doing. Triac P/N ( Link to datasheet?), volts, amps, ohms, reactances, Hz.
Do you need isolation? Some times you don't.
Ted
