How to Use a 555 Timer for PWM
pzentrady
Nov 29, 2005
11
i need to use PWM and i want to make it myself from 555timer.But i don't know how to make it if somebody there know please tell me about it
smokyLED
Sep 25, 2005
32
here's an example of a pwm to contorl a motor, http://www.dprg.org/tutorials/2005-11a/
otherwise the 555 datasheet might be useful, http://www.fairchildsemi.com/ds/NE%2FNE555.pdf
reuben1
Dec 12, 2005
9
ahhh!!!    thanks!  that's a better circuit than i the one i have,  I'll use that to drive the little power transistors that drive the really big ones that run the 15hp forklift motor that i installed in a subaru wagon to make a HE car.    RT
indulis
Nov 21, 2005
488
One thing that will happen when using a 555 as PWM is that the switching frequency will change with line and load.
reuben1
Dec 12, 2005
9
I did notice that,  the circuit i have runs at several hundred Hz with a lot of frequency change along with the pulse width change,  i ran a tape recorder motor with it, it ran fine from 0 to full speed, then put a  speaker on it to hear what it's doing.  I'll try this one and see if it does better.
smokyLED
Sep 25, 2005
32
you should post of picture of the 15hp motor installed in ur car :D
