How to use a BJT as a switch..
8
89Panadol
How to use a BJT as a switch...I want 2 connected the alarm circuit and UltraSonic Radar...please anyone tell me..
www.electronworks.co.uk
Aug 21, 2009
17
get two pnp transistors. connect their emitters together and connect these to the power input. Drive the bases low via a 10k resistor. Take the outputs from each collector.
Once again, your posts do not make a lot of sense. If you used proper English, you might get more help.
At a guess, I think the above answers your question.
8
89Panadol
oo..then i  connected the alarm circuit to the collector....
audioguru2
Apr 6, 2004
12,022
The ultrasonic Radar circuit is not Radar and is not Sonar. It is a simple motion detector with a short range.
It has a transistor output to activate an alarm but I don't know which alarm circuit you have.
8
89Panadol
i get the alarm circuit from this website
http://www.redcircuits.com/Page84.htm
how i can connect it to the Ultrasonic radar...
8
89Panadol
ooo thank you very much....now i understand how to connect the circuit...and congratulation for fast reply and your help....yahoooo.. ;D ;D
8
89Panadol
how about the IC 741 OPAMP...Could i change it like your advice in other forum..
audioguru2
Apr 6, 2004
12,022
The very old circuit already had its extremely old opamp changed to a 741 opamp. The first opamp needed C3 but the 741 opamp does not need C3.
I would use inexpensive, low noise and wide bandwidth TL071 opamps in this project.
