how to write c code for motor
vead
Nov 27, 2011
473
How to write c code for motor
if motor move forward
14,309
main()
motor_on();
This could work. Depends on how motor_on() is implemented.
O.k., that was the fun part. You have to supply a lot more information on your project:
- What kind of controller do you use?
- What kind of motor do you use?
- How is the motor attached to the controller?
- Do you have any libraries for motor control you might use?
Harald
jackorocko
Apr 4, 2010
1,284
Code:
main()
motor_on();
That didn't work, thought you where smarter then that? :D
jackorocko
Apr 4, 2010
1,284
vead, on a serious note, do you understand what harald is trying to say? You really left us with no way to help you. Did you get it figured out or are you still stuck? If you still need help we will need you to answer haralds questions.
vead
Nov 27, 2011
473
hi jackorocko i am really sorry if i did make any mistake . i am new in embedded c . i have not join c class i want to learn myself. so first thing came in my mind how to make c program for
microcontroller. if i should get basic of embedded c then i can make small program for system so first i decide to learn simple program as motor move forward ,LED turn on off
actually i am searching platform of embedded c which is use in every embedded system
and again sorry for my bad English
thanks
jackorocko
Apr 4, 2010
1,284
Well my best advice is to search google for code in the language you want to learn. Reading and playing around with code that already works is a great way to learn the language.
what type of micro-controllers have you looked at? If you are interested in the PIC's. Sorry, it is in english. http://www.gooligum.com.au/tutorials/baseline/PIC_Base_C_1.pdf
edit: I had to remove the first link, the author has decided to charge for his material and advertising for commercial profit is prohibited on these boards.
14,309
jackorocko is right.
My personal opinion: Programming in embedded C is structurally not too different from programming in C on a PC. The BIG differences are:
- in the embedded world your ressources are very limited (little memory, slow CPU, mostly no floating point unit, little mass memory etc.). Mind that this is a very general statement. I know very well that there are embedded CPUs with floating point and even with lots of memory etc.
- in the embedded world you have direct access to a lot of low level periphery. For example you can read a single input pin of the CPU or you can set a single output pin of the CPU. Both possible in the PC world only with lots of effort.
- in the embedded world you often have to deal with real-time requirement´s, menaing that you may have to guarantee a rsponse of the CPU to an input event within a limited (and mostly well defined´) time frame.
So if you want to control a motor, before you start writing your first line of code you need to know:
- How is the motor connected to the CPU?
- Which pins of the CPU (or maybe a peripheral chip) control the motor? What logic levels are required for "forward"?
- How is the program informed to start and stop the motor (pushbuttons? other events?)
For starters you may have a look at the arduino platform (which doesn't mean that jackorocko's suggestion of a PIC is not a good idea). The arduino comes with lots of libraries and so called "shields" for different I/O purposes. Unfortunately that's about all i know about the arduino.
Harald
vead
Nov 27, 2011
473
hi Harald and jackorocko
you have both done very great work for me thank you very much its very big help for me
i have tried to write some code please check me
The robot move over pipe. The IR sensor is used to sense The pipe when infrared signal fall on white surface its gets reflected and if it fall on black surface it is not reflected
#include<pic.h>
#define sensor_3
#define motor1_4
#define motor2_5
main()
DDRA=OXFF; //port A as input
DDRB=OXFF; // port B as output
if(sensor==1); //sensor on
(motor1=motor2=1); //motor run forward
if (sensor==0); //sensor off
(motor1=motor2=0); //motor stop
i don't know how to set low and high pin
i hope you will reply
thanks
14,309
I'm not versed in PIC programming. However, there should be a command simiar to
PORTB = <value>;
where <value> is an 8 bit data that defines the states of the port bits B0..B7.
For example:
PORTB= 0x01;
will set B0 = high, B1...B7 = Low
This seems easy, but beware: there is a pitfall here: The command as written above will set all port bits to low or high according to the bit pattern of <value>, disregarding your intent that you probably may want to set a single port bit only. To achieve this, you have to first read the current state of the port bits, change the one bit you want to be set or reset and write the modified port bits.
To set a single bit you use the OR function, ORing the bit pattern of the port with a bit maskt that sets the single bit you want to change, but leaves the rest unchanged:
TMP = PORTA; /* read port bits */
TMP = TMP | 0x01; /* set bit 0 to 1, note: unchanged bits are 0 in the bit mask*/
PORTA = TMP; /* write new port bits */
To reset a single bit you use the AND function. ANDing the bit pattern of the port with a bit mask that resets the single bit you want to change, but leaves the rest unchanged:
TMP = AND | 0xFE; /* reset bit 0 to 0, note: unchanged bits are 1 in the bit mask*/
You have to know which port pins your motor is attached to and what logic levels are required to start and stop the motor.
Harald
vead
Nov 27, 2011
473
PORTB = <value>;
For example:
PORTB= 0x01;
Harald
for example
i have two port
port A as input
port B as output
port A pin A0 A1 A2 A3 A4 A5 A6 A7
port B pin B0 B1 B2 B3 B4 B5 B6 B7
output of sensor connected to A4
motor1 connected to pin B2 B3
motor2 connected to pin B4 B5
logic level
sensor motor1 motor2
low low low
high high high
if sensor low motor stop
if sensor high motor move forward
how to write statement
DDRA=OXFF; // port A as input
PORTA=...?; //set sensor low or high
i am confused here how to write statement for input output port and to set high and low pin
how to write hexa code
14,309
You're not supposed to "set sensor low or high". The sensor is an input and should be read by a statement like
Sensor = PORTA & 0x08 /hex 08 = 0000 1000 -> only bit A4 is relevant, all other bits in "Sensor" are set to 0.
Similarly setting port pins on PORTB follows the scheme I wrote in my previous answer. Please re-read.
About Hex-Code you can read up here: http://www.theproblemsite.com/codes/hex.asp
May I suggest you first get some experience with writing C code at all before you tackle embedded programming? To me it looks like your fighting at two fronts at the same time. Get a grip on C-programming first, then apply your knowledge to embedded programming and learn the specifics.
Otherwise you may have a look at this course: http://www.swarthmore.edu/NatSci/echeeve1/Ref/C for PIC/C_Intro.html
Harald
timothy48342
Nov 28, 2011
218
vead, make sure your not mixing up the upper case letter "O" and the number "0". (zero) Even though they look similar on the screen, the compiler treats them different. 0xff is number. Oxff doesn't mean anything.
The define command doesn't use an equal sign, so:
#define PORTB 0x01
... will set that value at compile-time. (The pre-compiler swaps out "PORTB" with "0x01" in one of the first compiler passes.)
When setting variables at run-time, code like this:
motor1=motor2=1; //or even like this (motor1=motor2=1);
will set both variables motor1 and also motor2 to the value 1.
A lot of people won't know that, so it good to seperate those out for clarity.
motor1=1;
motor2=1;
When posting c-code it is good to put some spacing before some lines to make it easier to read and put [ code] before your code and [/code] after so that the message board keep the spacing, like this:
Code:
#define DO_IT 1
#include <hello.h>
void main()
     if( DO_IT > 0 )
          //it will always do my function
          Do_My_Function();
     //thats' all
Since I don't know much about microcontrollers. Which one is this that you guys are talking about? (So I can follow along and learn.) Would I look up "PIC microcontroller" or something else?
--tim
jackorocko
Apr 4, 2010
1,284
to add to what harald has said. Also, I take it you are using a AVR chip, Or don't you have a clue?
Code:
DDRA = 0x00; //set all porta to input
DDRB = 0xFF; //set all portb to output
sensor = 0;
while(1) //infinite loop because it is always true
    sensor = PORTA & 0b00000100;
    if(sensor == 0b00000100) //if sensor is 'HIGH' turn on motor 1
        PORTB = 0b00001000;
14,309
From
#include<pic.h>
I assumed vead is using a PIC microcontroller. The DDRA and PORTA statements, on the other hand, look a lot like AVR.
I like that binary notion 0b00001000 instead of 0x08 because in this case it is a much more obvious solution for representing the bit mask. I didn't know that this notion is available in C (I use 0x notation all the time).
Since the motors are connected to 2 port pins each, both port pins need to be set and reset, not just one. Depending on the exact circuit, which vead hasn't disclosed to us yet, this could look like:
void motor_1_forward()
int temp;
temp = PORTB;
temp = temp & 0b11110111; /* B3 = 0 */
temp = temp | 0b00100000; /* B5 = 1 */
PORTB = temp;
void motor_1_backward()
int temp;
temp = PORTB;
temp = temp | 0b00001000; /* B3 = 1 */
temp = temp & 0b11011111; /* B5 = 0 */
PORTB = temp;
void motor_1_stop()
int temp;
temp = PORTB;
temp = temp | 0b00101000; /* B3 = B5 = 1 -> same logic level on both pins means no voltage differential on motor */
PORTB = temp;
Thes eroutines can be modified accordingly using other port pins for motor 2. From within the main program it is sufficient to call these routines.
By the way: It is good coding styöe to "hide" the binary representations by using #define statements for the preprocessor. This also eases maintenance. If, for example, you connect the motor(s) to other pins you just redefine the bit pattern in the #define statement.
Harald
vead
Nov 27, 2011
473
hi everybody
thanks giving long response
I have tried again please check
I am using avr
algorithm
If sensor is High -both motor move forward
If sensor is Low- stop both motor
PORT A A0 A1 A2 A3 A4 A5 A6 A7 output of sensor is connected to A4 pin
0 0 0 0 1 0 0 0
PORT B B0 B1 B2 B3 B4 B5 B6 B7 motor1 and motor2 connected pin 2345
0 0 1 1 1 1 0 0
[#include
main()
while(1)
DDRA=OXOO; //port A as input
DDRB=OXFF; //port B as output
PORTA=0b00001000; // set as high pin
PORTA=0b00000000; //set as low pin
If (port A=00001000); //If sensor is high
(port B=0b00111100); // both motor move forward
If (port A=00000000); //If sensor is Low
(port B=00000000); //stop both motor
14,309
I told you before: PORTA is an input, so the statement
doesn't make sense. You can read from PORTA, but not write to it.
And nobody can tell you whether tis staement
works unless you post the schematic circuit how the motor is attached to the port pins.
Harald
Harald
It may do something though. It could tun on the pull-up resistors for that single input.
But yeah, it certainly won't set a high value to an input (because that's kind of a meaningless assertion)
14,309
What I completely miss in the C-code presented is the inizialization of the AVR.
You need to:
- initialize the stack pointer
- initialize the clock system (whick clock: internal / external, which frequency etc.)
- initialize an other function blocks
Maybe you just left this out of the code you showed us to keep it short. But it is required, See here http://www.jarkonkotisivu.org/AVRcoder/ for a little tool to assist in generating the necessayr settings (and it even generates C-code!).
By the way, here http://iamsuhasm.wordpress.com/tutsproj/avr-gcc-tutorial/ is a tutorial on writing C-Code for the AVR controllers.
Harald
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
On the AVR, PORTA is an output register. If you want to READ the port, use PINA.
