how to write input and output for microcontroller ?
vead
Nov 27, 2011
473
hello experts
I want to write input and output for microcontroller in verilog langugae
I have tried to write code
Microcontroller has following function
· ALU
· Decoder
· Port
· Counter
· Interrupt
· Accumulator
· Stack pointer
· Data pointer
· Special function register
· Serial communication
· Internal rom
· External rom
· Internal ram
· External Ram
Verilog code
Code:
Module mcu (clk, rst, en, p_in, p_out, t_in, t_out, i_in,i_out, rx_in, tx_out ,a0,a1,a2,d0,d1,d2,d3,d4,d5,d6,d7,a,b,s0,s1,s2,f,........etc);
Rst= reset input
Clk=  clock input
En= enable input
Port
P_in=port input
P_out= port output
Timer
T_in = timer input
T_out = timer output
Interrupt
i_in= input for interrupt
i_out,= output for interrupt
ALU
A=input
B=input
So=input
S1=input
S2=input
F=output
Decoder
A0=input
A1=input
A2=input
D0=output
D1=output
D2=output
D3=output
D4=output
D5=output
D6=output
Can anyone teach me how to write input and output for microcontroller in verilog langugae ?
vead
Nov 27, 2011
473
look at this example
what is meaning of ifdef and endif ?
module oc8051_top (wb_rst_i, wb_clk_i,
//interface to instruction rom
wbi_adr_o,
wbi_dat_i,
wbi_stb_o,
wbi_ack_i,
wbi_cyc_o,
wbi_err_i,
//interface to data ram
wbd_dat_i,
wbd_dat_o,
wbd_adr_o,
wbd_we_o,
wbd_ack_i,
wbd_stb_o,
wbd_cyc_o,
wbd_err_i,
// interrupt interface
int0_i,
int1_i,
// port interface
`ifdef OC8051_PORTS
`ifdef OC8051_PORT0
p0_i,
p0_o,
`endif
`ifdef OC8051_PORT1
p1_i,
p1_o,
`endif
`ifdef OC8051_PORT2
p2_i,
p2_o,
`endif
`ifdef OC8051_PORT3
p3_i,
p3_o,
`endif
`endif
// serial interface
`ifdef OC8051_UART
rxd_i, txd_o,
`endif
// counter interface
`ifdef OC8051_TC01
t0_i, t1_i,
`endif
`ifdef OC8051_TC2
t2_i, t2ex_i,
`endif
// BIST
`ifdef OC8051_BIST
scanb_rst,
scanb_clk,
scanb_si,
scanb_so,
scanb_en,
`endif
// external access (active low)
ea_in
can we write this code in this manner ?
Code:
  wbi_adr_o,
wbi_dat_i,
wbi_stb_o,
wbi_ack_i,
wbi_cyc_o,
wbi_err_i,
  wbd_dat_i,
wbd_dat_o,
  wbd_adr_o,
wbd_we_o,
wbd_ack_i,
  wbd_stb_o,
wbd_cyc_o,
wbd_err_i,
  int0_i,
int1_i,
  p0_i,
  p0_o,
p1_i,
  p1_o,
p2_i,
  p2_o,
p3_i,
  p3_o,
rxd_i, txd_o,
t0_i, t1_i,
  t2_i, t2ex_i,
  scanb_rst,
  scanb_clk,
  scanb_si,
  scanb_so,
  scanb_en,
  ea_in
