John Smith
- Jan 1, 1970
- 0
Richard Henry said:
I think they are also available in spray cans from http://www.mouser.com and
from http://www.digikey.com/.
Richard Henry said:
Mouser has the AR stuff and at least 2 others. Digi-Key has the
Better in what respect and how does an "impression" compare withBy far the most common copper thickness is one ounce (1 oz.). This seems
like a rather strange unit of measure for thickness, and it is. It means
that one ounce of copper metal has been deposited evenly onto a surface of 1
square foot. This is a very unintuitive measurement in my mind, but that is
what we use. One ounce copper translates to a copper thickness of about 1.4
mills. 2 ounce copper is twice as thick, 4 ounce copper four times, etc.
Two ounce copper is sometimes used on boards that handle significant amounts
of power/current, but other thicker sizes are rarely used except sometimes
for special requirements in power electronics. Sometimes they use really
thick copper to make windings of really low profile high frequency
transformers.
They do make some spray on substances that are supposed to improve the
electrical peformance of the board surface. I've got some stuff by Tech
Spray "Fine-L-Kote AR" conformal coating in a spray can that claims to make
your circuit surface more rugged while having a strong dielectric strength.
My impression is a real professional solder mask is really quite a bit
better than this stuff.
actual specs like dielectric strength and resistance to humidity
and other stuff?
Ok... Just wondering. I haven't found any spray on solder maskWell I don't know for sure really. My impression is just an impression and
isn't based on any kind of scientific research or tests, nor on extensive
personal use. If you only spray on one coat though it seems really thin.
It is clear and very hard to see. Since you can't see it when you are done
I almost felt like I was wasting my time spraying nothing onto the board.
With only one coat it seems quite easy to scratch, presumably much easier
than with an ordinary solder mask. Perhaps more coats would yeild stronger
results. My suspicion is it probably does improve resistance to
humidity/corrosive atmospheres, but without any scientific tests YMMV.
That may be true, Mac. But, if you design UL now, there may be less to do
later. Lots of times they (the ones who have the say-so) say approval isn't
necessary, then sales finds out the competition is UL approved and the
crunch comes to get it for your own product.
Besides, using UL requirements for spacing seems to me to be a good design
starting point.
My 2 cents.
John
The rule of thumb is about: 10 mil / per Amp.
So, I would say somewhere between 50 mil and 100 mil.
D = The distance between trace centers.
H = The height of the trace from the ground plane.
%crosstalk = 1/1 + ((D/H) * 2) * 100
Without knowing D or H, I can't give you a number.
