HP11C emulators?
Joerg
Hello Folks,
Happened again. Bent over to solder something at a client, the trusty
HP11C slipped out the shirt pocket and hit the tile floor really hard.
This time the asterisk blinked and gave me a scare since you can't buy
these calculators anymore.
So, is there a good emulator for the HP11C? I found one here but it's
missing important stuff such as SCI and ENG display of entries and results:
http://www.hpcalc.org/hp48/pc/emulators/
I can find lots of HP48 emulators, usually free/shareware, but I got so
used to ye olde 11C.
BTW if someone else sees that asterisk in the lower left corner: It is
the low battery indicator and after a fall you may have to clean the
batteries, clean the contacts or adjust the contacts. Sometimes giving
the batteries a twirl fixes it.
Tim Wescott
Hello Folks,
results:
But Joerg, think how much more expensive it'll be when a whole laptop
falls out of your shirt pocket, not to mention the wear and tear on your
shirts!
I'm teaching myself Java by writing a generic RPN calculator, that _will_
include ENG and SCI mode (those are the next features scheduled, in
fact), as well as hex and octal. I'll post it on my site when it's done
enough.
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
BobW
Joerg said:
Hello Folks,
results:
BTW if someone else sees that asterisk in the lower left corner: It is the
batteries, clean the contacts or adjust the contacts. Sometimes giving the
Joerg,
If you repost on comp.sys.hp48 you will get a definitive answer.
By the way, the new HP35S is very nice, and it has the BIG enter key.
Paul Hovnanian P.E.
shirts!
enough.
See if you can build it in the J2ME environment. Then you'll be able to
run it on something like a Palm or other handheld (even a cell phone).
Jeff Liebermann
Ouch. I hope the tile didn't crack.
So, tear it apart and fix it:
<http://www.decodesystems.com/hp11c-apart.html>
<http://www.hpmuseum.org/hp11c.htm>
I've repaired about a dozen HP10c through HP16c series calculators.
Dirt under the domed keyboard contacts is the usual problem. Also
filthy display contacts. Careful cleaning and careful re-assembly
usually fixes it.
Drivel: I repair and collect HP calculators in my ever shrinking
spare time, but don't tell anyone.
Emulator? Get the real thing. There's one on eBay for $150, which is
more than a bit overpriced. The HPmuseum has prices varying from $45
to $212. Ouch.
Well, there's:
<http://www.hpcalc.org/details.php?id=6382>
but there's nothing to download.
This one's not free:
<http://rlm.vstore.ca/product_info.php/products_id/2>
Yet another for money:
<http://www.rlmtools.com/Calculators/11C/11Cmain.html>
Here's an HP11c emulator that runs on the HP48 or HP49 series.
<http://www.hrastprogrammer.com>
Yep. That usually means some dirt or water has crawled into the
battery compartment. I usually scotch tape the easy to fall off cover
to the case, which make it loss proof, and somewhat waterproof.
Jeff Liebermann
Almost forgot. Look into getting an HP15c as a replacement for the
11c. The 15c has matrix arithmetic and complex numbers, while the 11c
does not. Otherwise, they're the same.
If not, I have an HP35s, which is my current favorite:
<http://www.calculators-hp.com/35s.html>
About $50 to $60 anywhere.
<http://h30094.www3.hp.com/product.asp?sku=3587762&pagemode=ca>
<http://www.hpcc.org/datafile/V26Special/the35s.pdf>
<http://www.newageinc.com/hostedimages/calculators/default.html>
One quibble is that the keys are silk screened with white paint which
will rub off. Previous HP calculators had the labels molded into the
plastic keys. It comes with a case, which helps. Mine arrived with
some of the labels smeared.
One of the handiest features is that it will use fractions directly.
I never have figured out how to use the "HP Solver" correctly. Maybe
if I read the manual.
<http://www.newageinc.com/hostedimages/calculators/TRAINING/scientific.html>
Allan Herriman
Hello Folks,
I ended up using the program XCALC.EXE
http://www.tordivel.no/xcalc/
after I lost my HP15c when my baggage didn't pass through LAX one
time. (I checked it in at one end; it didn't come out the other.)
Xcale doesn't offer matrices, or programming, or have a solver, but
for most things it actually has a better user inteface than the 15c or
16c.
(Xcalc is a windows program, and is not to be confused with the (poor)
calculator that comes with X.)
Regards,
Allan
Joerg
shirts!
The shirt is a problem but the laptop is a mil-style deal. Metal, rubber
bumpers on all corners, the works. Plus I need it anyhow to view
Gerbers, schematics, documents, etc.
enough.
Yes!
Joerg
BobW said:
Joerg,
Hmm, maybe I should consider getting one of these, if they aren't bigger
than the HP11C. Must absolutely fit into a shirt pocket. A belt holster
would be ok, too.
Joerg
usually fixes it.
to $212. Ouch.
Well, there's:
Doesn't have to be free. Price is reasonable, main thing is that _all_
the keys work, not just some. For example I really need to switch
between Fixed (for budget calcs) and ENG notation (for da real stuff...).
Good idea!
Joerg
16c.
Thanks, I'll try that. As long as it's RPN I should be able to get used
to it. But first my wife wants me to repair the dreaded sink. Drips a
bit, those darn compression joints. I already see it coming. Contortion,
then back pain, then some more back pain ...
BobW
would be ok, too.
The 35S is about an inch longer than my 12C&15C, but almost exactly the same
width and (average) thickness. It weighs about the same, too.
Get your shirts tailored, buy the 35S, and then tell your wife to fix that
damn sink herself!
Joerg
damn sink herself!
Well, the pressure cooker also needed some TLC. Sink will be done this
afternoon. Saturday is Honey-Do day around here. But my wife is quite
handy with tools. When I met her for the first time I was impressed that
the purse of a marketeer contained, among the usual women things, a
screwdriver, a pair of pliers etc.
K
krw
sci.electronics.design, [email protected]
says...
Hello Folks,
Not an 11C emulator (they exist but I didn't much care for them),
but XCALC is an excellent (free) RPN calculator.
Did you do a web search? There are emulators that use the original
HP microcode for the 11/12/16 and a bunch of others.
The HP35 has been resurrected as the 35s and has, I think, all the
functions you want. I just bought new batteries for my HP45 (and a
carrier for AAAs), but at $60 I might spring for a 35 and keep the
45 in the place of honor next to my VersaLog. ;-)
I really need (better) binary functions though. Anyone know of a
good calculator with binary fixed point arithmetic? That's one
shortcoming of XCALC (no binary point). I'd even spring for a PDA
if there were a *good* calculator for it. I paid $400 (1973 $$)
for a '45, so a couple hundred in '07 should be easy to come up
with. ;-)
That would have been good to know, if someone hadn't "liberated" my
11C.
K
krw
usually fixes it.
Ever repaired an HP45's power switch? Mine is quite touchy after
thirty years sitting in a drawer.
Joerg
says...
Yes, I'll chekc out xcalc.
Did a web search and found some but all were lacking ENG notation.
That's really important, especially when tired. Too easy to miss a
decimal point.
with. ;-)
AFAIK PDAs don't have stellar battery life. That's the most important
parameter to me with all things portable. The HP11C is the secret hero
in that domain. It ran 15 (!) years on the first set. Only my wife's
alarm clock that she got from our ultrasound company beats that. Over 20
years on the first battery and still humming.
11C.
Sad. I don't really understand people who do that.
Jeff Liebermann
This might help:
<http://802.11junk.com/jeffl/pics/hp-calc/hpcalc03.jpg>
The calculators from left to right are HP35, HP35S, HP16c, and HP41CX.
The 35s and the 16c are almost exactly the same width. The *average*
thickness is about the same. However, the HP35s is about an inch
longer. If you shove the 35s in your shirt pocket, without a
protective case, methinks the legends are going to wear off from the
keys.
damn sink herself!
Tear the sink apart. Make a huge mess in the kitchen. Then, ask her
if you can buy yourself a new calculator (implying that you're not
going to put her sink back together unless you get your new
calculator). That will either result in instant permission, or a
divorce. No warranty on my advice expressed or implied.
Jeff Liebermann
Sure. What's probably happened is that the grease that lubes the
slide switch has turned to tar and is not making contact. You can
sometimes get away with just applying some mild solvent (alcohol) to
the switch, slide it back and forth, and sorta smear the grease
around.
However, if you've been moving the switch back and forth zillions of
times, then you've probably worn a grove in the gold contacts on the
circuit board. That will require disassembly.
<http://www.hpmuseum.org/disasm.htm>
Try not to wreck the stick on label when you peel back the corners. I
use a hot air gun to soften the glue (and hopefully not melt the
plastic case).
I've been fixing switch contact pads with gold leaf and very tiny wire
(available at art supply and hobby shops) which are a real nightmare
to use. The stuff sticks to everything and won't release. For
practice, try cutting and applying a single layer of toilet paper
without ripping it apart. Good luck.
If it's really been sitting for 30 years in a drawer, the NiCad
batteries are dead, leaking, rotted, corroded, and disgusting. Don't
try to charge it if the batteries are swollen or covered with white
crud. They're ordinary 850ma-hr NiCad batteries and the battery pack
can easily be rebuilt.
<http://www.cs.uiowa.edu/~jones/hp/battery/>
If there's corrosion damage and white crud on the inside, just clean
it off with water and some mild solvent such as alcohol. Don't get
anything near the keyboard or capillary action will suck in the
liquids. Blow away the excess water, let air dry for a day, and you
have a chance.
Also, check the shorting bar inside the charger connector, which has
the bad habit of becoming intermittent. It may not be a bad on-off
switch but a flaky shorting bar. Just clean the round pins around the
shorting bar.
HP45 Crystal modification:
<http://www.hpmuseum.org/45crys.htm>
<http://www.decodesystems.com/hp45-stopwatch.html>
Drivel: Ancient photos of an HP65 rebuild.
<http://802.11junk.com/jeffl/pics/hp-calc/index.html>
K
krw
This might help:
keys.
Doesn't HP still use the keys with the color molded in (like
Model-M's)?
That's the way I generally justify new tools, but SFMBO would never
buy the calculator-sink connection. Now I just tell her that stuff
is a business expense. ;-)
K
krw
around.
plastic case).
have a chance.
shorting bar.
Cool, thanks. I've sent this to my email.
