HP7475A transformer secondary voltage and power rating ?
Peter_purple
Hi chaps,
I'm trying to revitalise an older HP7475A (Hewlett Packard)
desktop A3 plotter and found the power supply input transformer primary
has gone kafffuuuff,
I'm wondering if anyone out there knows what the secondary push-pull
voltage should be so I can insert a substitute, unfortunately there are
no markings on the transformer and the only clue on the main circuit
board is the power supply filtering cap which has a max voltage rating
of 25V,
so I'm wondering if the secondary is 12v or 24v push-pull and the rating
looks like maybe 2 Amps,
Anyone have any ideas ?
Regards
purple engine from perth packed pickled peppers
Peter_purple said:
Hi chaps,
of 25V,
Regards
Output was 12V AC @ 2A. If I remember correctly.
Peter_purple
Ah - yeah that sounds about right, I guess any higher then that and
they would have used a higher voltage electro for headroom, I'll
give it a try over weekend or the kids,
rgds
peter purple no longer perplexed from perth
Peter_purple
All fixed now,
Turned out to be corroded connections on the transformer lugs !
Now I need to lubricate the bearings and remove spider floss from
the optical encoders... <sigh>
rgds
peter purple from perth
