audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
If the generator is grounded to exactly the same point as the mains, and used the same wires to your equipment, then the problem of hum shouldn't exist.
exactly it is grounded to exactly the same point as the mains, and used the same wires to the equipments.audioguru said:If the generator is grounded to exactly the same point as the mains, and used the same wires to your equipment, then the problem of hum shouldn't exist.
Could be like that, I don't know what would happen if the ground at the generator isn't as good as the one comming from the power company or vice verse.Maybe the generator is grounded at its location, far from the mains ground.
tnk2k you are right that's a good way to check that everything is ok from the generator.I think we covered these earlier on. Walid got it narrowed down to generator induced as it does not show up when running on regular power. That would indicate posssible miswiring of the generator or improper ground connections or incompatible output configuration. Worse case he should get a power monitor unit to capture the generator power configuration: phase voltages, phase currents, ground current and have it evaluated for proper impedance loading and grounding.
Hee, hee. ;D ;D Maybe you could cram some memory modules for cameras into your head. But 1st you'll need to add a low-dropout 3.3V regulator for them, 'cause your existing brain probably operates at the obsolete 5V. Maybe you could also fit some little hard drives from MP3 players in there somewhere. ;D ;D4-1000A said:I should have updated my memory which become shorter and shorter, got to replace it with a new one with higher speed and size.
