Shaun
- Jan 1, 1970
- 0
Archimedes' Lever said:That is what I said, dumbfuck.
No it's not. You talked about all sorts of variations.
If you had read my hole post you would have seen that I mentioned that right
after quote above. See below
I know you
don't have the brains to come up with that your self or even put together a
paragraph like that.
Archimedes' Lever said:NOT voltage, idiot. CURRENT causes fibrillation.
You lose, again.
Archimedes' Lever said:I made HV medical device supplies. I know about what the limits are
and what the design constraints are.
Operating room defib paddles run at around 2mA during a cycle.
Grow the **** up.
The problem with your hole post is that it was as wholly insignificant
as this last post of your was.
Do *NOT* bet on that combo as being unlikely..
More like a 'Post Hole'
"hole post", ALwaysWrong?
Again you
never read my hole post. LEARN to read Dimbulb!
The energy level of a defibrillator is measured in JOULES, a joule is
watt*seconds. A defibrillator (monophasic) starts at 1 joule and goes up
to 360 joules on most machines.
Defibs run around 60 amps peak with pulse widths of a few
milliseconds. You are wrong by a factor of about 30,000:1, about
average for you.
Dirk Bruere at NeoPax wrote...
Right you are. As I clarified earlier, I was thinking of a
component postmortem.
Except that he was referring to the chip. D'oh!
30 KV per centimeter is the breakdown gradient of air. But that number
only correlates to spark gap length when the eectric field is even just
before breakdown.
In the usual case of people charging themselves up by shuffling their
shoes on carpet, they make sparks in gaps with uneven electric field. So,
less than 30 KV can make a 1 cm spark. If one end of the spark gap is a
sharp point or the tip of a wire maybe AWG 22 (approx. .63 mm) or smaller,
then a 1 cm spark can occur from about 11 KV, easily from 12KV.
Also, these sparks often appear bigger than they are. I find 1 cm to be
uncommon, but I find 8 mm fairly easy to achieve with favorable shoes and
a fairly favorable carpet and favorable humidity. So, I think 10 KV is
common but much more is not.
However, I remember experiencing one apartment with one exceptionally
favorable carpet and I somewhat remember making 15 mm, possibly 18 mm
sparks (corresponding to probably about 17 to possibly 20 KV).
More proof that the Williams bitch is getting more senile as each day
passes.
Read HIS post, you pissy little bitch.
My post is a proper, humorous correction post.
Your post is retarded baby bullshit.
Also, given the hypothesized rapid rise time, doesn't most of the
current flow on the surface ie skin - a literal "skin effect"?
OK - I get it now!
I did that once with an expensive chip.
A guy passed it to me and, unthinking, as I went to take it there was a
big fat spark that leapt through its pins. Straight to the rubbish bin.
and no doubt
absolutely fatal to anything more sensitive than a vacuum tube.
