hi,
I am building an ozone generator using a high voltage neon sign transformer and I am a little unsure of wiring. The transformer I have is brand new and runs off 230v and produces 3kv@9ma. I want to be 100% sure of how to wire this safely for obvious reason so I would appreciate your assistance guys/gals.
Basically the nst that I have bought is like in the image attached.
The ozone generator electrodes will consist of a scroll of stainless steel mesh that is pushed into a Pyrex test-tube where it unfurls against the walls and a lug on the end makes connection to the circuit through a nut and bolt through the screw-on lid. A stainless steel mesh tube on the outside of the test-tube acts as the other mesh electrode and is connected to ground via the terry clip mountings that hold the assembly in place.
The secondary side of my transformer is not marked, do I simply ground one side of the secondary (which will be the outer electrode) and tie this to the case also?
