I have a problem form Amplifier voltage divide
mourad3d
Is a problem that the ability to show me that the program Multisim itself is not showing me in the following accounts
Where the capacity of the planned 1.2 ml Watt, but the 8 Micro program show what the cause of it
Knowing that the impedance of the biggest income impedance phase out Alsabaky
Attachment files
voltage_divide_-_1.pdf
  • voltage_divide_-_1.pdf
liquibyte
What?  Can you slow down and try that again, maybe in your native language and we'll translate?
mourad3d
thank you
This amplifier circuit in the form of voltage divide
I make some calculations to extract the circuit's capacity was 1.2 ml Watt
When the work program of simulation result of the ability did not show the exact reason for this
mourad3d
Ok the schematic Can you Download of the link
http://www.m3dmax.com/3d/Tran.zip
I'm doing you the ability accounts, but the ability to Multisim program different Wayne error results
liquibyte
Someone else might be able to help you but I can't run Multisim, my OS is Linux and it won't run in WINE.
audioguru2
Apr 6, 2004
12,022
I do not know why so many calculations were made for the very simple circuit, most of the calculations are not needed to simply find the RMS power in the 5K ohms load.
I simulated the circuit with LTspiceIV and it shows an output power of 9.0uW in the 5k ohms load.
liquibyte
Interesting waveforms.  That's one of the things I love most about this program.  Here's an LTSpice IV file I did.
Draft1.asc.zip
  • Draft1.asc.zip
mourad3d
Are you can How calculations output power In this circle of if load 5k ohms To be equal to simulation
liquibyte
I get 410 microwatts or 41 milliwatts unless I'm doing the math wrong.
Right click the name of the waveform at the top and attach cursor one to the first waveform and cursor two to the second and hover over each and move them to the peaks.  The window that pops up will show you the resultant value for the waveforms and then you do the math on those two values.
Hero999
Oct 28, 2007
2,433
You need to wait until the steady state, before attempting to calculate the power in the load. When the power is first applied, there will be a power surge as the DC bias voltage stabilises; it takes awhile for the capacitors in the circuit to charge.
Once the steady state has been reached, the RMS power in the load can easily be calculated: PRMS = Vpk-pk2/8RL
audioguru2
Apr 6, 2004
12,022
Liquibyte,
You have the transistor shorted with a wire from its collector to its emitter instead of a 10M voltmeter.
liquibyte
audioguru said:
Liquibyte,
I knew there must be something wrong.  Thanks.
Hero999
Oct 28, 2007
2,433
After correcting liquidbytes's simulation, the steady state power dissipation in R6 is 3.9994µW.
mourad3d
Ok, if you make accounts equal ability not be this problem
