alex ezorsky-lie
- Aug 27, 2015
- 27
- Joined
- Aug 27, 2015
- Messages
- 27
A friend of mine recently picked up a free grove labs indoor aquaponics ecosystem,
. Basically it's an aquaponics tank above a fish tank and they feed eachother using pumps and drip systems. There are also lights, one for the fish and one for the plants, and there's an additional set of fans for the plants (though not totally necessary). My friend says it was working before we moved it. The company has since tanked (pun intended) and their support is not helpful.
So currently nothing we do helps in getting anything in the system (lights/fans) to turn on. The power supply light is green. There is also a removable chip on the board labeled "SPARK" with a slowly glowing white light. So it seems there is power.
The board has two modes:
"Grove OS" - Where cycle length, power etc. can be programmed via your phone app by connecting via wifi
"Control panel" - Where these functions can be set manually by dials on the board.
The control panel mode seems most easily testable and least likely to fail so that's the method I'm trying to get working first but so far I have tried:
1. Both OS and CPanel mode
2. Every switch combo on CPanel mode (including constant on for lights and fan)
3. Unplugging the power supply and all internal plugs, plugging them back in, and then plugging AC back in.
4. Pressing the two little buttons on the SPARK circuit. (the left one turns the little chip light off when pressed)
5. Holding down the two little buttons on the SPARK circuit for at least 5 seconds each and also together.
6. Plugging the lights and fans into different plug ports (there are 4 options for fans/peripheral, 3 for lights, and 4 for sensors)
I've done some minimal parts testing and I will update this list as I test more things:
So far the readouts for:
12V (TP12/TP_GND) - 11.95V
5V (TP5V/TP_GND) - 4.95V
TP_A3 (connection from board to CPanel) - 0.24V
TP_A1 (light block) 2.48V
I know this is an unusual device, but it is also much more simple than most of the TV's etc. I see people getting help with on these forums. It would also be a fantastic thing if we could solve this problem as the company donated a handful of these setups to local schools and they are experiencing similar problems.
Thanks!
MAIN BOARD
COMPLETE SETUP
POWER SUPPLY GREEN LIGHT (lower right)
LITTLE "SPARK" BOARD AND LIGHT (I think this is the programmable "Brain" which allows for wifi stuff too. Maybe a Pi knockoff?)
LIGHTS AND FANS (There is another light as well)
THE PANEL (setup the way I imagine should me most likely to turn something on) (also none of the lights on the front panel light up)
Thanks!
MAIN BOARD
COMPLETE SETUP
