I need a "watt meter" to measure consumption of my home applicances
N
NeXTstep
I would like to measure the consumption of my home server, "from the wall".
Can anyone suggest a good watt meter for such a purpose?
I have heard about "kill-a-watt" but it is only available for the US
market - no use for me since I need an european version.
"Watts up? PRO" does not seems to be accurate, and is very expensive.
any suggestions?
TIA,
Gianluca Bosco
There is a European version. Keep looking. It looks a lot like the US
version, with a different receptacle on the face.
Nick
samc
any suggestions?
TIA,
Gianluca Bosco
for uk ?
try : http://www.maplin.co.uk
http://www.machinemart.co.uk/
http://www.argos.co.uk
I fetched my wh-meter (brennenstuhl brand) from a machine mart store .
R L driver
any suggestions?
TIA,
Gianluca Bosco
There plug in watt meters that measure voltage , current, pf, watts and
running costs for less than £20 on ebay ... type in "watt meter."
steve the grease
danny burstein
In said:
It sounds like there are other things available, but wouldn't a US
Kill-a-watt with appropriate adapter plugs work?
I would expect that:
volts are volts
hz are hz
amps are amps
yes? no? why not?
The KAW is rated for 120 Volts. Messy things might
happen if you try it on the 240 or so volt European standard.
That being said... I risked one of mine on a US circuit
and got unusuable and ridiculous looking displays on it
(no damage, though).
However... I was actually hooked into two legs of
a three phase crcuti, giving me 208VAC and a wierd
wave form, which may have confused it even more.
One of these days, RSN, I'll find a single phase 240V AC
line and plug it into that.
(there are two common ways of getting so-called 220V
in a typical building in the US. Most often you've
got two hot legs that are 120V to neutral, and that
are 180 degrees (out of 360) apart. Hence one leg is,
loosely speaking, "pulling" when the other's "pushing".
If you tap hot<-> neutral you get 120V AC
if you tap hit <-> hot, you get 120_120 =240 (which
lots of people call 220. don't ask)...
On the other hand, you can also have a three phase
situaition, wherer you've got three live legs coming
off the transformer (plus neuutral). These are
all 120 degrees apart (that 120 number is purely
conincidentally the same as 120 volts).
If you tap hot <-> neutral, you get the sam 120 VAC
If you tap hot<->hot, you get 120*(sqrt of 3) = 208V AC.
You also get a funky wave form.
Most, but quite definitely NOT all, 240 volt appliances
will work ok at the 208 figure.
(You'd use all three hot wires for a high power item
such as an elevator motor)
JoeSP
any suggestions?
TIA,
Gianluca Bosco
I get by with the watt rating stamped on the appliance. If it's using more
than that, it's probably getting hot, trips a breaker, and won't last long
anyway.
JoeSP
Not anal enough I guess.
philkryder said:
Have you ever validated that method by actually measuring to see if
what is stamped on the device is even close to what is actually used?
W
William P.N. Smith
The nameplate is a maximum, the actual consumption could easily be a
fraction (well under half) of the nameplate rating. Using the
nameplate is a good first approximation, and certainly won't be an
overestimate, but an actual measurement is going to be much better in
most circumstances. In the case of the OP, the power supply input
power rating of his server isn't going to be anywhere _near_ his
actual consumption.
I've got golf cart chargers with a 1.2KW nameplate rating, care to
guess what's the actual KWHR consumption of them when charging
typically-discharged carts overnight (12 hours)? Would anyone use
14.4KWHR as an answer?
