i need help extending the keys finder project. can someone help me out????
logan_dslasher
Jul 23, 2004
392
i must have totally logged out.. maybe it remembered my login info.. i'm sorry..
anyway, i think i'll just stick with the elctret mic i have.. my adviser just called.. he wants me to come over his house.. we're going to work on the project.. i have to go.. i'll let you know what we can accomplish..
bye..
audioguru2
Apr 6, 2004
12,022
Don't forget your discovery that the CD4049 is a lousy linear amplifier and that a CD4069 would be better, would operate with less current  has fewer number of pins so is smaller.
Good luck.
logan_dslasher
Jul 23, 2004
392
hi! this day was not like what i imagined it to be.. when my adviser and i met this afternoon, he asked if i had everything with me. i said yes. he asked for the circuit. i handed it to him. he also asked for the spare components i have, including the bread board.. i also gave him the printouts i have - those that were from this forum and also the msn conversations.. after that, he walked away..  he's going to work on the circuit by himself. he said he will just give it to me at school on MOnday... i never got the chance to try the things that you have advised me...
anyway, i guess it's better this way.. at least  he won't totallt blame me if this thing doesn't really work.. maybe, i'll just tell you how his work on the circuit went when i see him on MOnday..
How will i learn if i can't see how my project is done?  :(
logan_dslasher
Jul 23, 2004
392
good day! has anybody built the whistle responder circuit and made it work? my adviser thinks it'll never work.. he said that the IC used (CD4069 CMOS Hex Inverter) can never be used as an amplifier..
i want to know if anybody had already made the circuit with a 4069 IC..even if you haven't built it, i need your opinion if a 4069 can be used as an amplifier like that in the whistle responder circuit..
thanks again..
logan_dslasher
Jul 23, 2004
392
thanks again..
correction.. i mean a CD4049.. i got confused.. sorry...
Staigen1
Oct 26, 2003
695
Hi Logan
Your adviser is totally wrong, it can be used as an amplifier, and a good amp too!
You almost had it working when your adviser took it apart from you, he should be ashamed!
//Staigen
logan_dslasher
Jul 23, 2004
392
hey! i need proof! can you please give me alink to a site or something that says all about this CD4049.. all i'm getting out of google are PDFs.. they usually contain basic infos..
Staigen1
Oct 26, 2003
695
Hi
There is an aplication note fron RCA about this, i will check later for the name of it!
//Staigen
audioguru2
Apr 6, 2004
12,022
Hi logan,
I have used the CD4069 as a linear amplifier many times and it works well. RCA had an appl. note which is also in National's AN-88 applications note about their 74C04, which is the same as the CD4069.
The CD4069 is completely symmetrical, so operates very well as a linear amplifier and has a fairly low current so has symmetry with high gain.
The CD4049 is fairly high current and is terribly assymmetrical. I haven't seen one. Since it is high current then I think its gain will be low.
logan_dslasher
Jul 23, 2004
392
A 4069 is better than a 4049, right? i will try a 4069.. have to go now.. i have a class.. i will re-design the circuit while attending my class. i'll have it sent to you for checking..
thanks..
audioguru2
Apr 6, 2004
12,022
My 1st graph shows that a CD4069 or 74C04 inverter with a 3V supply and a high resistance as a negative feedback resistor and a low resistance as its inverting input resistor has a voltage gain of about 500 at low frequencies. The Whistle Responder mic preamp can't have a low value for its input resistor so its gain will be a little less than 500.
Our Keys Finder Project uses CD4069 inverters as linear amps.
logan_dslasher
Jul 23, 2004
392
hi!
i skipped class to ask you guys about something.. my adviser wired the circuit in the breadboard.. he said that although he wired it correctly and have the same output voltage, the circuit is still not functioning.. he concluded that the circuit will not function.. he said that i should replace the linear amplifiers.. IC1a, IC1b, and IC1c.. he wants me to replace it with transistors or OPamps.. i don't know how? is that possible? how am i suppose to wire them?
i still  think it would be better to use a 4069 instead.. but i am not sure if i will make the correct design with a 4069.. it has only 14 pins compared with 16 on the 4049.. besides, it has a different pin configuration..
logan_dslasher
Jul 23, 2004
392
so the pin equivalent is:
  4049                            4069
pin 3                  =            pin1
pin 5                  =            pin3
pin 7                  =            pin5
so on...
are my assumptions correct?
logan_dslasher
Jul 23, 2004
392
Everybody's sleeping!!  :(
can you please confirm my assumptions as soon as you are available? thanks a lot.. i'll wait..  ;)
Staigen1
Oct 26, 2003
695
Hi Logan
I found the appnote on my computer in the end, it was not in the book! ;D
I found two versions of it!
Here they are:
//Staigen
AN-88.pdf
AN-0088.pdf
  • AN-88.pdf
  • AN-0088.pdf
audioguru2
Apr 6, 2004
12,022
Here is another applications note about the voltage input vs the voltage output of ordinary Cmos logic that is applicable to using inverters as linear amplifiers. The ouput Mosfets are perfectly symmetrical:
AN-90.pdf
  • AN-90.pdf
logan_dslasher
Jul 23, 2004
392
what can you say about my professor's idea that i replace the inverters with transistors and opamps? i read them tomorrow.. i have to go now.. tahnks..
