i need help very badly
gg200
Apr 13, 2012
24
i dont no about resisters, the only thing i know is that they can cut off some of the power flow.
heres my problem i got 2 items i want to put lights in but i dont know or cant find out a wat to know what kind of resister they need in ohms.
so one was a ps2 slim i put a light in and it blow up and the other item is a 3 channel receiver to my rc car i want to put a power light on it. i try but i cook the receiver up.
i try to study resisters everyone on you tube and google dont speak english where u can understand. try google but no that does not help.
ok i wonna know what kind of ohms do i need on my ps2, i have a 8.5v and a 5.3 amps. i dont know what those numbers mean but i can find help on that.
my rc car radio take 4 aa batterys butt i dont have a cloe to find out what resisters ohms u need.
i need english i dont need nerd talk no offense to anyone. but i dont know electroinics but i want to to do mods of my own ideas and by my mind..
guys i dont know what to say but i dont know **** and i need help, you tube sucks google sucks i need something im hungry for eleltronics.
Wabajig
Apr 14, 2012
75
You might want to buy a adjustable Resistor substitution box and place in the highest ohm position (M ohms) to start, and connect in series with LED or small lamp. Slowly adjust substitution box until light comes on at comfortable level. Look at the resistor you need on the box. Remember if the resistor is too small in size it may get too hot, get bigger resistor. Keep the same value in ohms though. Also LED's only work in one direction, so be careful. Also goto Library, resistors are the most basic thing to learn in electronics. Good Luck and always be careful with electricity. John
CocaCola
Apr 7, 2012
3,635
this anit heping me.
Why not? It will give you all the answers to you questions if you actually read it... Or better stated it gives you all the tools you need to get the answers to your question with just a little work by yourself...
The answers to your questions are dependent on the characteristics of the light or LED you decide to use, as well as the supply powering them, there is simply no single right answer until you assemble all the pieces of the puzzle...
You need to at least try, no one can help you if you don't want to actually help yourself and try...
BTW this is English, (with some basic Math) not nerd talk...
gg200
Apr 13, 2012
24
hey dude can you tell me how me ohms i need for my ps2 slim it take 2.5v and 5.3 amps?
also tell me why do those numbers have points in between?
can you also tell me how meny ohms i need for a receiver that takes 4 AA batterys?
theres just mix info back and forth i dont understand none of it i just know soldering.
14,487
seriously !! ? how old are you ? have you not done any basic maths at school ?
the first day of any basic maths would have taught you about decimal points
you still havent told us if you are wanting to use LED's or light globes ??
gg200
Apr 13, 2012
24
no i dont understand thr point between the two numbers and how my schooling as a child years ago is my busness.yes i never was taght decimal points so u can have your fun now, i know how this is gonna go:rolleyes:
If LEDs, the colour is important.
If bulbs, the voltage rating is important. If it doesn't closely match the power supply (8.5V?) then the current or power rating of the lamps is also needed.
Knowing how many is also good.
gg200
Apr 13, 2012
24
im not talking about lamps im talking about a game system amd a rc car radio system read my story before comment pls.
CocaCola
Apr 7, 2012
3,635
I'm going to assume a Troll at this point, and bow out before my head implodes...
gg200
Apr 13, 2012
24
say what u want, i find it veery hard to see why lots of people cant be simple to a begnner.
in this case by your way of talking to me your the troll.
I made a bad mistake of being a member on here:(
CocaCola
Apr 7, 2012
3,635
This is as simple as it gets...
Resistor in Ohms is equal to
Source voltage
minus
LED forward voltage
........ Get this number, simple subtraction, got it? ........
take that value you got above and divided by
the ideal LED forward current in Amps, it's likely rated in mA (15mA = 0.015 Amps or 20mA = 0.020 Amps for example)
The end result is the minimum resistor value you need in Ohms...
Subtraction and addition are all that is needed, but if you have no concept of decimals it's likely over your head...
This is easily garnished info from the LED page linked...
No, you want to put lights in it.
Let me remind you:
So tell us about these lights first and we can move on from there.
gg200
Apr 13, 2012
24
can u give me a link on how to do these decimals in electronics.
the only decimals i know is in money. but it wont hurt to link me to a site that can show me how decimals work in electrionics.
i will try to study the rest of what you told me and see if i can master this .
CocaCola
Apr 7, 2012
3,635
www.google.com
Really, the search field is also a calculator, that fully handles decimals...
Base 10 decimals are decimals be it money or electronics...
gg200
Apr 13, 2012
24
Let me remind you:
ok i got rainbow leds from ebay i dont remember the info on them. so my attempt on trying to mod the thing did not work out. i put wires under the part where the power cord plugs in to and then the led.
when i plug in the ps2, the light lasted for 2 sec and it blow right up. i had the thing plug in a power strip so i save my system and from a fire as well.
my idea was to put a led light on the from right hand side vents on the system. which is right under the power button.
now as for the traxxes radio Receiver i wanted to have a power light on it . i did the very same thing like i did on my ps2 . well the Traxxas Receiver got cook. heres a link of what it look like.
http://www.nitrorcx.com/traxxas-receiver-2215.html?gclid=COC6jJ-vs68CFcJM4Aodjk2gjQ
CocaCola
Apr 7, 2012
3,635
Go to your Ebay account and look at you past purchases, and see if the auction is still archived... If no find the seller on Ebay and see ifhe/she is still offering them...
With no knowledge of the LEDs requirements any guess at a resistor is just that, a guess...
gg200
Apr 13, 2012
24
ok i been thinking when they say 1.5v battery, is that . 5 volt drop or is that amps?
there has to be a reason for the other number so ether the other number meins a volt drop or amps.
i try that google thing and the wbsite are kinda strange.
if i can find out what thve .5 stands for then i can try to maybe do better at my study on this.
CocaCola
Apr 7, 2012
3,635
Neither it's 1½ volts...
No other number it's a single value, it's not 1 volt, it's not 2 volts, but it is in fact 1.5 volts or 1½ volts...
.5 = ½
