I need project ideas
Anon_LG
Jun 24, 2014
453
I am stuck on what to build next, preferably I would like to make a project the involves digital electronics. I know how to input sensors into digital circuits and understand logic, flip flop memory, dividers, adders etc. I have access to just about all the digital components I need using Maplin and RS components, I do not have microcontrollers. If it involves some electronics being outside this is fine as I have a radio transmitter and receiver. Does anyone have ideas for a project under £30?
How about a break-beam detector that uses a modulated beam and triggers based on a missing pulse detector.
See what sort of range you can get between the transmitter and the receiver without false triggering.
This neatly combines analog and digital.
Use your knowledge to design something from scratch rather than looking on the net for ideas.
For extra bonus, do it with a laser diode and see if you can set it up over a distance of 30 metres or more (in daylight).
Anon_LG
Jun 24, 2014
453
Thanks for the idea steve
Is there anything you could suggest I could use this to control/activate?
An alarm or announcer come to mind.
KMoffett
Jan 21, 2009
723
Double the beams, and send the outputs to logic and an up-down counter to conut the number of things going in and out through a portal.
Ken
Or measure the interval and use it to measure speed.
