Chris
- Jan 1, 1970
- 0
Jonathan said:Here is another possibility, where the opto section on the phone line
side doesn't require a power supply at all (and it loads the line
perhaps a little less than your example, even so) and where it is
possible to actually observe the line voltage by counting pulses. It's
a voltage to frequency converter. The other side of the opto will
require power, of course. Another difference is that the pulse
frequency would need to be handled:
I kept all the resistors of the same value, except for R5 which is
needed to help current limit at times, in case that helps any. I
think the frequency will vary roughly linearly with voltage, at about
10Hz/volt or so.
Jon
Rudy -- Forget the cobble I gave you -- this circuit is kewl. If you
feel you can handle the added complexity, go for it. I printed Jon's
circuit out, and I'm going to perf it up the next time I go to the lab
just to see it go.
I was actually considering offering you a relaxation oscillator using a
cap and a diac discharging through the opto, but they don't make 'em
like they used to -- minimum trigger voltage these days can be well
over your specified 30V.
Many thanks, Jon. You gave me a laugh -- elegant simplicity, sir.
Cheers
Chris
