I need to get some basic transformer theory help
gav
hello,
this may be a stupid question but...
Is it possible to run a mains (50hz) power transformer at a much higher
frequency or will it become very inefficient (are there increased hysteresis
losses) ? I'm talking 150hz-10khz or so.
I don't think it will be able to but don't understand the theory.
Gavin.
Phil Allison
** Wise disclaimer....
** Depends on the transformer. For most E-core types losses will
increase above about 400 Hz - due mostly to leakage inductance. For
toroidals the frequency range is much higher - to 10 kHz at least and 100
kHz in some cases.
Where exactly did you expect to find 240 volts at 10 kHz ??
............ Phil
Adrian Jansen
No, transformers are optimised for a specific frequency range. In general,
operating at any frequency outside around 10% lower, and 100% higher in
frequency will severely degrade performance. Get a good basic book on
electronic theory, and you will learn why.
Regards,
Adrian Jansen
J & K MicroSystems
Microcomputer solutions for industrial control
Phil Allison
** A book on "electronic theory" will not give much info on mains
transformers, better get one on electrical theory.
There is no problem with most E-I transformers at 400 Hz and all
toroidals go fine to 10kHz - at least.
Only split bobbin designs have high leakage reactance.
........... Phil
gav
I don't know. But mains 50hz transformers are easy to get my hands on at
jaycar.
I need it for step up in any case.
Gavin
Phil Allison
jaycar.
** Trying to make some big sparks ??
Nicola Tesla style ?
.............. Phil
gav
-any recomendations? I'm doing an electrical apprenticeship and my books
don't go much beyond turns ratio/voltage calculations.
gav
If you're thinking of several KHz or higher, then Amidon sell some really
chunky ferrite toroids that make great trannies.
I meant 150hz-1khz.. oops.
thanks but.
gavin
Adrian Jansen
Much simpler to make DC out of it, using the alternator built-in rectifier
and a battery, then a DC-DC converter to get the voltage you want. Avoids
all the tricky problems of regulating the alternator so you dont blow up the
transformer. Not to say those of designing a special transformer to cover a
wide frequency range and voltage input as well.
Regards,
Adrian Jansen
J & K MicroSystems
gav
Wheres the fun in that :)
thanks anyway.
gavin
