I2S
Myauk
Where can I read the principles of I2S?
I found it in some Audio CODEC applications.
I do not know the reason why it uses three different clocks Master
Clock, Bit Clock and Data Alignment Clock.
I understand the Data Alignment Clock generally the the left and right
audio signals in digital format alternately on a single line in serial.
But still why are there bit clock and master clock.
Where can I find out about all this theories as well as other
requirements for a complete Full Duplex system of inter chip
communication.
Regards
me
communication.
Regards
Google is a good place to start...
Eeyore
Google ? Wikipedia ?
All the audio DACs and ADCs I can think of need only L/R_clock ( word clock )
and bit_clock.
http://en.wikipedia.org/wiki/I2S
What do you actually want to *know* ?
Graham
Myauk
and bit_clock.
Graham
I am studying about the Wolfson WM8776.
http://www.wolfsonmicro.com/support/whitepaper/audio/
I generally understand that an audio file contains audio information
with different sample rates.
So L/R clock defines the periods in which Left and Right Audio Signals
in PCM format would be agreed to trasmit and receive between the Master
and Slave Devices, then the bit_clock is just a reference to determine
the sample rate at which the PCM signal is transmitted, and then Master
Clock, I hope, is just for infromation.
Correct me if I am wrong.
I am reading as much as I could but I need help for faster learning.
Eeyore
You seem to have it pretty much correct.
Bit clock is simply used to clock in each bit of serial data.
I've yet to see a system that uses M_clk.
Graham
Myauk
Graham
There are other DAC ICs that uses M_Clk such as CS4351; they all use
four lines for data communication: Bit, Master, Left/Right clocks!
From wikipedia, I understand that I2C uses only two lines serial clock,
and serial data, and I 2S uses three: Bit clock line, Word clock line
(also called word select line), And at least one multiplexed data line.
But where does that Master Clock come from?
I am reading through the wolfson white papers to understand more about
it.
Regards
Eeyore
Dare I say, the master clock oscillator ! All the others are just divided down
from it.
Graham
Myauk
from it.
Graham
Yes, now I understand about it.
The fundamental concept require only three types, the bit, the L/R
clock signals and the data signal.
But they are just inventing new concept of Master clock for a few
reasons.
Here, see this,
http://www.wolfsonmicro.com/uploads/documents/en/MCLK_fs_whitepaper_Rev12.pdf.
Now I can figure out the general concept of Data transimssion and
receiving for Audio Systems.
Thank you for your colloborative suggestions.
Regards
