IBM G50 Monitor Repair Info Needed - HELP ! !
Getafix74
I have got an IBM G50 monitor, which works well some of the time.
Every once in a while it looses the picture and the screen goes dead.
If I hit it on the caseing just behind the tube then it flickers back
on for about 3 seconds, then goes dead again. Once this happens I have
to wait for it to cool down again, abot 2 hours wait, then I just pray
it works!......sometimes it works, sometimes it don't!!
I have looked around the net and it seems that it may just be a
resistor or bad soldering, has anyone got any ideas? but i'm not sure
how to tackle it!
Can anyone help cos I don't want to get rid of the monitor, and don't
mind having ago at fixing it.....
Rono
Main board likely needs resoldering! Try in the
horizontal hold, & power supply areas! Rono.
I have the case open now, where do I look for the horizontal
hold?.....i have not really done this before! i have had a good look
for loose or broken soldering, but i cannot see anything! Would I be
able to see anything like that? or do I need some equipment?
I have the case open now, where do I look for the horizontal hold &
power supply?
The little green LED at the front always stays on.....does that mean
the power supply is OK?
Occasionally it makes a really annoying high pitched whining.....does
this mean anything?
Thanks for replying, by the way! appreciate the help!
new at this type of repair !
I have the case open now, where do I look for the horizontal­ hold &
power supply?
The little green LED at the front always stays on.....does t­hat mean
Occasionally it makes a really annoying high pitched whining­.....does
this mean anything?
getafix74
power supply?
this mean anything?
getafix74
sorted it .....thanx... it was the power supply soldering. a bit of a
2wiggle and it working again....for now
