IBM Squaer network cable What is it called?
Michael Kennedy
I have a few IBM network cables with square connectors on the end. I believe
it is some form of token ring but I have no idea what the connector is
called. Is there any demand for these cables? I got it from a closing
grocery store.
Bob in Phx
The cables are most likely type/cat 1. With a token ring type A connector.
They are very obsolete.
Here is a web page with the various types of type 1 cable ends.
http://www.pacificcable.com/TokenRing.htm
Note that type/cat 1 is shielded twisted pair and in fact is much better
then Cat 5 cable as it is shielded. If memory serves correctly, the max
length is 1500 feet for token ring, on this type cable.
bob in phx
gb
believe it is some form of token ring but I have no idea what the connector
is called. Is there any demand for these cables? I got it from a closing
grocery store.
IBM cabling system Type 1 ... 2 pair 18 AWG as I remember - circa 1980s.
Plugged into a passive MAU
BTW, the founder and president of my current firm is the US TR patent holder
for this (and worked for IBM Scandinavia in 1970s - where it was originally
developed)
gb
gb
bob in phx
Well partially right. After the 1984 Judge Green legal decision (breaking
up AT&T - so AT&T could go into the computer business to compete against
IBM)
IBM developed a "Type cabling system" in an attempt to standardize the data
cabling infrastructures -- for the vendor (mfg) specific & proprietary
cabling solutions (e.g. Datapoint had ARCnet with RG-62/U 93 ohm cable;
Ethernet has 10-Base-2 and 10-Base-5 used 50 ohm coax cables; Proteon ProNet
4 & 10 which used shielded twisted pair; AT&T had StarLAN; Novell had
StarNet)
I installed Type 1 cabling during 1980s and it was a bear to retrofit into
existing buildings. Improper termination at the patch panel caused most of
the problems -- cable installers hated the stuff.
AT&T desired to reuse existing Bell installed unshielded twisted pair
cabling. I believe that Anixter was the first with AT&T to developed the
"Category designations (Cat 1; Cat 2; Cat 3). I once had all of this PHY
specification documentation from 1970s and 1980s - but finally pitched much
of it in late 1990s.
gb
