ICOM M802 and SCS TRXPTC?
Having successfully installed one in an M802 I would like to know if anyone
here has one or a Bluetooth SCS modem. Seems the Bluetooth range is short.
Works great if you are close enough.
Larry
anyone here has one or a Bluetooth SCS modem. Seems the Bluetooth
range is short. Works great if you are close enough.
Bluetooth range standard is 10 meters, but it's on 2400 Mhz so almost
anything blocks the signal, including your body which is unfortunate.
I use a Motorola S9 Bluetooth headset from a bluetooth netbook computer.
The headset receiver sits on the back of your neck. It's range suffers
when you're walking towards the computer, and you're head is absorbing the
signal.
Meindert Sprang
Class 1 bluetooth range is 100 meters. And I get very good reports of people
using a MiniPlex-BT, a bluetooth enabled NMEA multiplexer. Even when sitting
on an outrigger of a tri, the datalink to the centre hull is solid.
Meindert
Larry
people using a MiniPlex-BT, a bluetooth enabled NMEA multiplexer. Even
when sitting on an outrigger of a tri, the datalink to the centre hull
is solid.
Meindert
.....but I bet Dave is talking about a CONSUMER Bluetooth device, not some
commercial system costing thousands.
Cisco makes fantastic routers and servers, too, but we're all running
CONSUMER equipment.....
Meindert Sprang
Only EUR 285 retail....
Meindert
Bruce in alaska
Well, not ALL of us are running consumer Gear.....
manati
Jul 20, 2009
Hi Dave,
i read Your notice about having installed an Pactor zrxptc in a ICOM M802. I live on a boat and I'm just installing my Radio. I ordered a Pactor TRXPTC for my M802. I realized that there are no installation guides coming with the modem. If I have prblems installing it, would You be so kind to tell me how You have done it?
Thank You very much for your help,
Pierre witschger
Ship Manati HBY4306, Switzerland, actually in Normandy, France
