ICSP in PIC18F4550 using LVP enabled
at89atbits
Sep 20, 2014
39
I want to program my PIC18F4550 TQFP in LVP mode using ICSP.
However I am unsure of how PGM is supposed to be connected.
I read the datasheet and I searched online but I haven't gotten a clear view of the PGM pin connection yet.
Can someone please help me with the circuit for PGM pin on PIC18F4550 so that i can program my PIC in low voltage.
Gryd3
Jun 25, 2014
4,098
Forgive my ignorance, but my understanding is that the PIC itself requires 12V to program. (The USB programmers have circuitry to supply this.)
Arouse1973
Adam
Dec 18, 2013
5,178
Page 312 of datasheet
While programming using Single-Supply Programming,
VDD is applied to the MCLR/VPP/RE3 pin as in
normal execution mode. To enter Programming mode,
VDD is applied to the PGM pin."
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
That's one way to do it.
Gryd3
Jun 25, 2014
4,098
Just went through the datasheet for that one.
Self-Programmability: These devices can write to
their own program memory spaces under internal
software control. By using a bootloader routine,
located in the protected Boot Block at the top of
program memory, it becomes possible to create an
application that can update itself in the field.
I like this feature ;)
And I was incorrect on the 12V requirement for this particular PIC
Arouse1973
Adam
Dec 18, 2013
5,178
It also means for safety critical applications if one micro stops working a supervisor micro can re-program it.
Adam
