idea for creating Touch sensitive wire strip like variable resistor
Vignesh0025
Jul 4, 2013
9
Hii, I want to create a touch sensitive wire strip... That is .. When i move my hand over a copper wire
Well, there is not much variation in voltage along a copper wire unless it is drawing a LOT of current, so I don't see how.
14,487
you could create a capacitive touchpad <--- google it
you need to understand you need 2 wires
CDRIVE
May 8, 2012
4,960
That's partially true. One leg can be commited to ground leaving only one conductor as the capacitive pickup. I think it might be prone to false triggering though.
Chris
Vignesh0025
Jul 4, 2013
9
I searched for capacitive touchpad but could not find able to find any actual idea to work it out?? Where can i find the details??
CDRIVE
May 8, 2012
4,960
If you're looking for a simple finger bridging circuit that demonstrates where along a resistive divider your finger has bridged the circuit you can put this together. I show a 9V battery and an Ammeter but a basic Ohmmeter will work just as well. Placing your finger across any of the 4 touch points will give a different Ammeter or Ohmmeter reading.
Chris
Well, there is not much variation in voltage along a copper wire...
On a technical note, this applies only if the length of the wire is short compared to the wavelength of the signal.
CDRIVE
May 8, 2012
4,960
Are you referring to SWR?
Chris
No, I'm referring to the propagation of a signal through a conductor.
If the conductor is short compared to the wavelength, you can consider the signal identical throughout the length of the wire, and the signal at both ends are the same.
If the wire is long, both ends of the wire could be at different potentials.
As toy realize, an antenna is a perfect example. However, regardless of SWR the effect still happens.
CDRIVE
May 8, 2012
4,960
Yes, but this does not hold true for transmission lines properly terminated in it's characteristic impedance at both ends. In this case the only differences from input to output should be dielectric and radiation loss. Usually,the more expensive the transmission line the less one should see in either regard.
Chris
CDRIVE
May 8, 2012
4,960
Steve, brain fart on this end! Yes, you're absolutely correct and so was Toy. My last post I was still stuck on SWR, which is better described and stated as Reflected Power. It has little to do with Toy's theory.
Yes, that's how antennas work! ;)
Chris
