BlackMelon
- Aug 7, 2012
- 189
- Joined
- Aug 7, 2012
- Messages
- 189
Hello, I was trying to identify those pins. I have already found the BASE pin by using a digital multimeter(DMM), put the + of DMM on one pin and - on the other which gave me equal ohm readings.
When I was trying to find emitter and collector, I used the technique that I put DMM's + and - on the two pins which was not the BASE (Let's call them PIN1 and PIN3) to measure resistance between them. I connected R 1k ohms from PIN1 of transistor to BASE then read the resistance. After reading ohms, I moved the 1k to between BASE and PIN3 of transistor and then read the resistance too. I almost concluded that the PIN1 is a collector cuz I've got much lower collector-emitter resistance reading than the other case
But after I swapped + and - on PIN1 and PIN3, the ohms reading is reversed with the first time (when I connected resistance from PIN1 to Base, I got a much greater collector-emitter resistance)
How can I identify which pin is Collector or Emitter
Thank you
Thank you
