IF choices
Pritam
Mar 24, 2016
Hello dears,
My question is, Why IF (Intermediate frequency) doesn't lie within RF (radio frequency) range.
14,487
Hello dears,
hi
welcome to EP :)
they do, where did you think they were ?
dorke
Jun 20, 2015
2,342
You need to rephrase your question.
Did you mean to ask,
Why is the IF frequency outside the frequency band of a receiver?
14,487
not sure if that helps ;)
for some multi band radios there can be multiple IF's and can be within the range of normal reception
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
The purpose of an IF is to allow tight control of the bandwidth and gain of the IF amplifier, thus improving the selectivity of the receiver. As @davenn mentioned, some receivers (especially higher frequency receivers) have two or more IF amplifiers because of the requirements of the local oscillator and mixer circuitry. It all depends on what kind of receiver you are designing. If the receiver is to tune from DC to light, a lot more than one IF will be necessary.
14,487
and also, to bring the frequency down to one that is more easily demodulated to recover the information
455kHz or thereabouts is a very common base IF freq. and has been since the dawn of radio receivers
The next very common combination is 1st IF of 10.7 MHz then down to 2nd IF of 455kHz
One radio I have has a number of different IF freq's depending on what band is being used
I have highlighted them in red
ramussons
Jun 10, 2014
475
Common combination? :confused: The only place where I've seen this is in a SCPC satellite receiver channel modem :D
14,487
then you haven't done much RF work ! ;)
it VERY common in commercial comms equip
dorke
Jun 20, 2015
2,342
An interesting link ,the history part especially IF.
There is also the term "zero IF" ,
which actually means a "direct receiver".
And another note on the issue:
One important parameter of receivers is " IF rejection ratio" .
ramussons
Jun 10, 2014
475
I linked the term "common" to common broadcast radios :D not to professional equipment. Did'nt think the OP had gone to that level of explanation.
14,487
yup a few ham friends have played with zero IF ( direct conversion ) haven't done so myself
you might find this interesting .....
http://lea.hamradio.si/~s53mv/zifssb/block.html
That's a VERY limited view ;)
and I wasn't referring to professional equip ... I said commercial comms
think of radio gear used in taxi's, couriers and a dozen other similar uses
In older, and occasionally slightly newer microwave linking gear, 70MHz was/is
the common base band IF
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Not sure about other IFs, but 455 kHz was used in about a zillion superhet AM broadcast receivers dating back to the early part of the 20th Century. The reason it became so popular was a self-fulfilling feedback from the number of receivers using it and the availability of "standard" IF transformers for inter-stage coupling with built-in tuning capacitors and slug adjustments for the inductor core.
One of the first test instruments that I purchased back in the 1950s or early 1960s (I forget exactly when), right after assembling an EICO kit oscilloscope, was a sweep frequency generator (with markers!) that I used to adjust the bandwidth of television video IF amplifiers. This was almost never necessary unless a customer had helpfully "tightened down" all the slugs in the IF transformers in their misguided attempts at repair... usually after running all the vacuum tubes through a drug-store tube tester and replacing all the "bad" tubes.
Were it not for transistors, drug stores would still be raking in big bux selling replacement tubes their "testers" had discovered were "bad". Transistors also spelled the demise of TV repair shops because transistors hardly ever failed. I managed to get out of the TV repair business after graduating from high school by joining the Air Force. The Air Force also introduced me to better toys, which carried over to an engineering career after my four-year hitch was up..
Another "favorite" IF is 10.7 MHz, used in maybe a half-zillion superhet FM broadcast receivers, also dating back to the early part of the 20th Century.
This Wikipedia article has a pretty good overview of how, when, where, and why IFs are used in communications receivers, along with a list of IFs that have been used in commercial equipment. The designer, of course, is free to choose whatever IF will suit the purpose of their design.
dorke
Jun 20, 2015
2,342
"The Air Force also introduced me to better toys, which carried over to an engineering career after my four-year hitch was up.."
Does the names CEI and WJ ring a bell?
"Another "favorite" IF is 10.7 MHz, used in maybe a half-zillion superhet FM broadcast receivers, also dating back to the early part of the 20th Century."
A small correction:
Commercial broadcast FM radios is an after WWII thing.
"This Wikipedia article has a pretty good overview of how, when, where, and why IFs are used in communications receivers, along with a list of IFs that have been used in commercial equipment."
I linked to that one in #9;)
Some common frequencies absent are 10MHz and 2MHz .
and the "modern " digital TVs ones at 36MHZ and 44MHz .
14,487
Correct. Thank u.
for simple one or two band radios, this is commonly the case. But in multi band radios as the one I described earlier and another one I own
that have general coverage receivers ... ALL the IF freq's fall within the covered range of the receiver, even the 455kHz, as the radio
is capable of going down to 150 kHz in receive mode.
As the radio tunes across the spectrum, the micro controller is switching IF freq's to keep the received frequency and the used IF frequency as far apart as possible
"Another "favorite" IF is 10.7 MHz, used in maybe a half-zillion superhet FM broadcast receivers, ."
as I mentioned way back ;)
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Opps! I apologize for "stealing" your link. I must have opened it in a new tab while reading your post #9, read the article, then forgot how I "happened" to have it open. <sigh> My short-term memory is becoming worse every day that I age.
Anyway, I hope the link and the responses from others has helped @Pritam understand IFs a little better.
dorke
Jun 20, 2015
2,342
Not a problem at all and no need to apologize.
I just noted that, to point a common view.
I actually like it when it happens...;)
