if invert a sound wave
thunder1
Sep 13, 2004
56
if sound wave is inverted will it be understadable or not?or it will not effect on the sound
audioguru2
Apr 6, 2004
12,022
Hi Thunder,
You can demonstrate the effect of an inverted sound wave easily by reversing the two wire connections to a speaker. It will sound exactly the same, but will no longer be in phase with other speakers that are connected.
If you add a non-inverted sound wave with an inverted one, they cancel. You can demonstrate this with a stereo. If you connect one of its speakers out-of-phase as above, the bass will be reduced unless the room is very echoy.
Put the two speakers facing each other about 2cm apart. When they are in-phase, the bass will be loud. Now reverse the connections of one speaker so that it is out-of-phase, and the bass cancels.
