Ignition Coil Fence Charger
Whfarms
Nov 12, 2023
10
Ran into a problem.
My simulation shows high dissipation in the SCR trigger when I increase circuit values to handle a 20J pulse.
I'll think some more about that, but have no obvious solution presently.
How low does the simulation require the Joules to go to work properly?
crutschow
May 7, 2021
991
About 10J.
Below is the LTspice sim of the circuit which stores 10J in the capacitor:
It is directly powered from the line (be carful when working on it and only plug it to a GFCI socket) so the required isolation to the fence is provided by a dual-output (lost spark) type coil which is isolated from primary to secondary (standard coils are not).
C1 is a low-cost, motor-run film type capacitor whose AC impedance efficiently limits the charging current through the rectifiers to the storage capacitor C2.
C1's value is selected to charge up C2 to the 100V trigger voltage in about a second.
C2 is a 2mF (2,000µF) electrolytic, that stores 10J of energy.
(That's about the maximum without overheating SCR U1)
When C2's voltage reaches 100V (green trace), Zener D4 turns on the transistor to fire the SCR and rapidly discharge the capacitor through the coil's primary to generate the spark (yellow trace).
The SCR dissipates about 2 watts in operation, so may need to be on a small heat-sink.
The diodes shown were the only 3A, 200V diodes I had a model for, but you may want to substitute 3A, 200V Schottky's for lower dissipation.
One caveat is that the circuit has only been simulated, not built, so some tweaking may be necessary to get a real circuit to work as desired.
Whfarms
Nov 12, 2023
10
This is great. I cant wait to build one and test it. I am learning alot about high voltage coils working on this project. Up to this point Ive done a bunch of programming and 110V-480V wiring but no real electronics work to speak of. Thanks for the help!
