Yes. But it is not as simple as giving you a number.
Bigger wire can carry more current than smaller wire. In theory, you could have 100s of wires connected to a single wire just as long as the single wire is big enough to handle the amps required.
Example.
22 Gauge wire can carry up to 1Amp, and if each bulb requires 150mA... then you can connect up to 6 bulbs and wires together in parallel to a single 22 gauge wire.
Each bulb can use thinner wire, just so long as the 'trunk' that all the wires connect to can take care of the sum of all of them.
I am not sure what your bulbs are pulling though, so I can't give you a ballpark figure to work with.
Example.
