I'm learning the art of amplifier design,know that replacing a collector load with a constant current source greatly improve the distortion of the amplifier,and now the problem is,how I determine the impedance of the constant current source?
You need to clarify your question. Are you asking "How do I calculate what the correct impedance of the current source should be in a particular amplifier stage", or... how I determine the impedance of the constant current source?
a current source doesn't have an equivalent resistance.
I get the info of CC from the web,of course they did not mention so much of it
I think (I'm not an expert) that using a constant current collector load would not reduce the distortion due to the Early effect, because the collector-emitter voltage would still be varying over a wide range. Using a current mirror as the load would work, because the collector-emitter voltage would not change significantly as the current through the transistor varied. But then the output transistor in the current mirror would suffer from the Early effect instead, if you ran it into a resistive load.I read the book "designing audio power amplifier" ,it do mention that replacing the collector load resistor with a constant current source will reduce the distortion cause by the early effect,I get the info of CC from the web,of course they did not mention so much of it,thank you for pointing out the problem,after all, I'm not a electrical nor a electronic engineer
I should have said that it's not meaningful to describe a current source as having a DC resistance. It is only meaningful to describe it as having an AC, incremental, or dynamic resistance. Would you agree with that?Weeeeell... It does. It may be dynamic, and it certainly has an ideal resistance. However I suspect that's not relevant.a current source doesn't have an equivalent resistance.
In this case, wouldn't a higher incremental resistance make it more difficult to stabilise the collector voltage? I was considering suggesting that he put a resistor in parallel with the current source, specifically to reduce the incremental resistance, for this reason. But anyway, what's the proper way to stabilise the collector voltage when the collector load is a current source?Have a look for the 2 transistor version of this circuit. It uses a more stable voltage (Vbe of a transistor) to set a voltage reference. One is demonstrated in section 3 (image 3.1) of this: https://www.electronicspoint.com/got-question-driving-leds-t256849.html There is also a link to where it came from which has some more explanation.
As I understand it, the reason for running a common emitter amplifier into a constant current load is to increase the stage's voltage gain.
Yes, and in fact the original question was of its impedance and the way of measuring it was by means of calculating the small signal response. And that's exactly what you're saying here.I should have said that it's not meaningful to describe a current source as having a DC resistance. It is only meaningful to describe it as having an AC, incremental, or dynamic resistance. Would you agree with that?
In the absence of feedback, that's true. But greater gain allows the feedback loop to exert more control.In this case, wouldn't a higher incremental resistance make it more difficult to stabilise the collector voltage? I was considering suggesting that he put a resistor in parallel with the current source, specifically to reduce the incremental resistance, for this reason. But anyway, what's the proper way to stabilise the collector voltage when the collector load is a current source?
