Implementing MQTT Communication with Mosquitto
ilianaboone
Aug 11, 2023
37
Mosquitto is a lightweight open-source MQTT (Message Queuing Telemetry Transport) message broker, widely used for efficient communication in IoT and distributed systems. Below is a structured guide to its deployment and usage
Core Features
  • Lightweight: Optimized for resource-constrained devices (e.g., Raspberry Pi).
  • Cross-Platform: Supports Linux, Windows, macOS.
  • QoS Levels:
    QoS 0 (At most once)
  • QoS 1 (At least once)
  • QoS 2 (Exactly once)
[*]Persistence: Stores messages on disk for session recovery after resta
Installation on Debian 12
  1. Install via APT:
    bash
    Code:
    sudo apt-get update && sudo apt-get install mosquitto
  2. Verify Service Status:
    bash
    Code:
    sudo systemctl status mosqui
Configuration
  1. Edit Config File:
    bash
    Code:
    sudo vim /etc/mosquitto/mosquitto.conf
  2. Key Settings:
    conf
    # Default MQTT port (plaintext)
    listener 1883
    # WebSocket support
    listener 9001
    protocol websockets
    # Allow anonymous connections (disable in production)
    allow_anonymous true
    # Log file path
    log_dest file /var/log/mosquitto/mosquitto.log
  3. Restart Service:
    bash
    Code:
    sudo systemctl restart mosquitt
Security Setup
  1. Create Password File:
    bash
    Code:
    sudo mosquitto_passwd -c /etc/mosquitto/passwd your_username
  2. Enforce Authentication:
    conf
    password_file /etc/mosquitto/passwd
    allow_anonymous false
  3. Restart Service:
    bash
    Code:
Testing with MQTTX
  1. Install MQTTX:
    Download from MQTTX官网.
  2. Connect to Broker:
    • Host: mqtt://your_server_ip:1883
    • Username/Password: Set if authentication is enabled.
  3. Publish/Subscribe:
    • Publish Topic: sensor/data
    • Subscribe Topic: device/comma
Serial Server Integration
  1. Hardware: Ebyte NE2-D11 serial server (product page).
  2. Configuration:
    • Set Work Mode to MQTT.
    • Enter broker IP/port and authentication details.
    • Define topics for data publishing/command subscription.
  3. Testing:
    • Use XCOM (serial tool) to send data → Verify reception in MQTTX.
    • Send commands via MQTTX → Confirm receipt in XCOM
Advanced Features
  • TLS/SSL Encryption:
    Uncomment listener 8883 and configure certificates.
  • Client ID Prefix:
    conf
    Code:
    clientid_prefix iot_device_
  • Logging & Debugging:
    Monitor logs with:
    bash
    Code:
    tail -f /var/log/mosquitto/mosquitto.
Best Practices
  1. Avoid Root Permissions: Use sudo for service management.
  2. Disable Anonymous Access in production.
  3. Buffer Day: Restart devices 1 day before returning to normal operation.
fussyplink
Apr 1, 2025
It is quite impressive to combine the MQTT Communication model with Mosquitto. Perhaps you should provide more simulation images to make it easier to understand.
Scratch Games, thanks!
