Eeyore said:
By popular request I've posted my latest version of an improved microphone
preamplifier here.
http://rapidshare.com/files/21272377/mic_amp_2.jpg
As it seems some can't see it on abse I've reposted it there too as 'improved
mic amp'
Graham
Thanks posting your design Graham. You obviously actually work in this
field, so I was hoping I could ask some questions regarding your design; or
design in general.
How would this design compare with one of the all-in-one ICs (like
http://www.analog.com/en/prod/0,2877,SSM2019,00.html)? Would they 'sound'
the same? I ask this for 2 reasons - one, I'm using a micpre that I made
using that IC, and two, if there performance ans sound is close, wouldn't it
be easier and cheaper just to use the IC? Is there something better about
the discrete approach?
I'm sure you're aware of much higher priced micpres like Focusrite, etc. Is
their design so radically different (and more expensive to implement)from
the type of design you have here, or is the difference in cost more due to
audiofoolery?
Along that same line, I've never had the $ to be able to use one of those
hi-end pres, so I can't make a direct comparison myself, but is there
something in the design of those really expensive micpres that makes them
more "musical" or appealing to the ears of musicians (I ask this because you
work in the field and so assume that you've heard some of these others, or
done some comparisons yourself)?
Thanks again
