Is there anyway this circuit could be improved?
chesschaser
Oct 20, 2024
10
Hi guys!
I'm learning electronics and have challenged myself to design a PWM dimmer circuit for a halogen bulb. I have build the circuit below and it works but I always want to learn from these so is there any way this could be improved?
14,317
Every circuit can be improved.
Always.
It mostly depends on your definition of "improved":
  • less parts
  • less cost
  • less power dissipation
  • less PCB real estate
  • higher reliability
  • better accuracy
What is it you want to improve?
chesschaser
Oct 20, 2024
10
Always.
  • less parts
  • less cost
  • better accuracy
The bulb whines at lower duty cycles. Is there any way this can be prevented?
14,317
Increase the frequency of the PWM above the audible range to e.g. 30 kHz.
14,317
The datasheet states a min. current gain bandwidth product of 3 @ 1 MHz. So 30 kHz should be a no brainer.
chesschaser
Oct 20, 2024
10
i measured the output and when i adjust the r2 potentiometer the frequency changes alongside the duty cycle. how can i prevent this?
14,317
Look up "555 fixed frequency pwm" using the search engine of your choice.
bertus
3,877
You could also try the following circuit:
Make C1 1 nF for higher pwm frequency.
Bertus
Alec_t
Jul 7, 2015
3,821
The configuration shown in post #1 only allows duty cycle adjustment between about 17% and 50%. Is that ok for your needs? If not, the post #12 configuration would be better as it allows almost 0% to 100% duty cycle variation.
Why does a change in frequency with duty cycle matter to you in this application?
